cost of lowering
Old Sep 26, 2004 | 12:30 AM
BRYAN BUSH's Avatar
Car: 91 Z28
Transmission: BORG-WARNER T-5
cost of lowering
what would be the average cost for me to lower my 91 Z28 about 1.5 -2 inches
Old Sep 26, 2004 | 12:56 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
If you do it yourself then its about 250 bucks for the springs.If you pay to have them done then it will be around 250 for labor.
Old Sep 26, 2004 | 03:05 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Don't forget the $40 for 2 new air dams to have in reserve so you can put in a new one back on when you knock one off on something.
Ed
Old Sep 26, 2004 | 01:40 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
250 for labor seems pretty expensive to me...
oh, and dont forget that you'll need a front end alignment.. mine was $86 at a tire store..
Old Sep 26, 2004 | 05:31 PM
nolanr0413's Avatar
Car: Trans am
200 for springs, 200 for front springs install, 109 for bolt in lower control arm relocators and 150 for an adjustable panhard bar. I didnt need a front end alignment , it sits good and doesnt wear the tires out , but maybe the 3000 miles i drive a year doesnt show up . o well. If you put springs in i think you should put in new shocks and struts too.,
Old Sep 26, 2004 | 06:04 PM
ebmiller88's Avatar
I went to the local Poncho dealer for an alignment and it was only $49...$86 was a screwing. My springs (New Eibachs) ran me $200 in the classifieds so keep an eye out for deals.
Ed
Old Sep 26, 2004 | 07:22 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
do you need bolt in lower control arm relocators ? when lowering a car
Old Sep 26, 2004 | 08:19 PM
BRYAN BUSH's Avatar
Car: 91 Z28
Thanks for all the info.It looks like it might be more costly than i hoped it would be
Old Sep 26, 2004 | 09:19 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
you dont necessarily need lca relocation brackets, new shocks/struts/ adjustable panhard rod.... out of all those, the panhard rod is what you should consider getting first since you'll need to re-center your rear end... but i've lowered my car and havent adjusted my panhard rod yet (i'm a lazy ***). you dont need new shocks and struts, but chances are lowering your car may shorten the life of the ones you have in, and you may have a blown set sooner or later.. and lca relocation brackets are needed only if you race it often, and need to eliminate wheelhop... these are the least urgent out of them all.
Old Sep 26, 2004 | 10:05 PM
ebmiller88's Avatar
Like posted above, need?...no. Good to have?...Yes
All in all, the only expense (IMO) that lowering would incur is:
1-Springs (Est $200);
2-Alignment (Est $50);
3-Adj panhard bar (Est $100).
So it's $350 by my math and assuming you do the install yourself, it's not that bad. (Click link in sig to see how to do it). That's it since you can rent a spring compressor from Auto Zone for free but for just removing the stock springs, it's not needed. They will just fall out when the A-arm gets low enough. It's also not "needed" when installing the new shorter springs anyway but it's nice to have. If you can get a semi good deal on springs, that's what you're looking at.
Maybe these are still available:
Sportline springs: https://www.thirdgen.org/classifieds...tgo?adid=50720
Lowering springs: https://www.thirdgen.org/classifieds...tgo?adid=51565
Tubular panhard rod: https://www.thirdgen.org/classifieds...tgo?adid=52186
adj panhard: https://www.thirdgen.org/classifieds...tgo?adid=51604
LCAs and panhard: https://www.thirdgen.org/classifieds...tgo?adid=50906
Good luck!
Ed
Old Sep 26, 2004 | 10:36 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
60 bucks for shock/struts, springs, adj panhard rod from a friend that did it in his garage.
Old Sep 27, 2004 | 03:16 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Lowering a car changes the steering geometry, your supposed to get an alignment
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
birdman_29
Jan 7, 2017 08:24 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
