shakin
Old Oct 21, 2004 | 11:45 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
shakin
Recently, only while idleing, I get some minor vibes. They are not severe and they go away with a little throttle. What things could cause this? motor mounts? BTW my tired TBI has near 200,000 miles.
Old Oct 21, 2004 | 11:49 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Tires are usually the first culprit. Since the vibrations go away after you hit the gas I would look at those. The tires will shake when they are at their natural frequency. Changing spees to either fast or slower beyond that point will stop the vibrations. That is until speed makes the tire unstable all together. An unbalanced driveshaft will also cause vibrations, but they will increase as speed increases.
Old Oct 21, 2004 | 11:58 AM
Engine: 5.7, 5.0
I should have been more clear. This only occurs when the the car is stopped and idling. It is definatley engine related. it seems to idle a little more rough than usual, but it's not that bad. The vibes definatly go with the engine idle, if that makes sense.
Old Oct 21, 2004 | 12:41 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
My RS does that too and it only has 70K on it. I think it might be something with my exhaust or emissions system (pressure, leak, etc.). It is perfectly smooth given a little throttle and the shakin is ever so slight only at idle. I'm not totally sure what it is, but just wanted to give my experience.
Old Oct 21, 2004 | 12:58 PM
Engine: 5.7, 5.0
And I have a nearly identical set up as you.
Iroc87Stud
Jul 18, 2011 07:08 AM
crazynights
Jul 31, 2004 06:41 PM
OUTATIME GTA
Jul 4, 2003 03:31 AM
OUTATIME GTA
Jul 4, 2003 02:26 AM
ImportsRsloths
Feb 28, 2002 11:13 AM
