Profab K Member Group Purchase
Old Oct 28, 2004 | 06:36 PM
smokin92z4's Avatar
I spoke with jeff at pro-fab about there k member for 82-92 with stock motor mounts and spring perches there 375.00 if i get 5 people he will sell them for 300.00 each plus like 20-25$ shipping they come any color i have 2 people i need 3 more please email me at smokin92z4@yahoo.com or call jeff at pro-fab 877-782-6470 and tell him you spoke with me thanks greg moss profabracing.com is there site
these are very nice k-members also he said we can buy the control arms for 250.00$
Old Oct 28, 2004 | 07:04 PM
smokin92z4's Avatar
please call jeff at pro-fab to order we need two more people to get the good deal thanks and please email me if you order it so i can keep track of how many people there are
thanks greg
Old Oct 28, 2004 | 10:32 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
damn, and i just bought a laptop and prom burning stuff. if anybody would be up for it this winter, ill try and start one
Old Oct 31, 2004 | 07:18 PM
smokin92z4's Avatar
we need 2 more people just call jeff at pro-fab
thanks greg
Old Nov 9, 2004 | 04:16 PM
primo's Avatar
I may be interested. What is the benefit of having it, what is the weight gain, whast type of material are they made of, is there a link to pro-fab????
Old Nov 9, 2004 | 10:03 PM
smokin92z4's Avatar
i installed mine tonight very nice quality its mild steel, the k member with the control arms weight is 21 lbs the stock stuffed weight is about 50-60 lbs also its very easy to work on and oil pan clearence is awsome,,,, highly rec.... please call profab and talk to SAM and tell him i sent you there web site is profabracing.homestead.com
thanks greg please email me if you order it
Old Nov 10, 2004 | 09:42 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
A word of caution.
I have direct info that those adjuster sleeves they are using for the coilover kits will break if you run them for alittle time then try and reposition them. Those adjuster sleeves are only .065" walls BEFORE they cuct the threaded adjustment provisions into them. Thats paper thin and scary. They also have no support on the upper fenderwells and the fenders will start to bulge under the mounts- Kandied has also confirmed this happping to his car (A second source)
Old Nov 10, 2004 | 04:01 PM
smokin92z4's Avatar
IM saying the k-members are great and the lower a- arms but i havent seen there coil over kits but everyone has a certain case
senareo on situations
Old Nov 11, 2004 | 06:24 AM
rstanko's Avatar
Engine: 434 SBC 648HP NA
I just installed my K-member last night and I agree they are nice. After weighing everything you end up saving right near 40 lbs, plus gain a bunch of clearance. Fit was right on with only one issue of the right rear mount for the A-arm, it was bent out slightly, but came back once the arm was tightened.
As for the coil-over kit, I stuck with the factory spring setup, as I am not convinced there is any great weight savings in the coil-over setup, maybe 6Lbs and the loss of strength in that area does not offset it.
Old Nov 12, 2004 | 09:25 AM
oil pan 4's Avatar
Car: 89 Firebird
Whens the money got to be up by?
I want to get 1 for the v6 and one for the z28 but will only have the money for 1 next week and right now the engine is out on the v6.
"i installed mine tonight very nice quality its mild steel, the k member with the control arms weight is 21 lbs the stock stuffed weight is about 50-60 lbs "
thanks now I have a boner.
Old Nov 12, 2004 | 02:32 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
I've heard that profab and PA racing is one and the same, if thats true...and these are chromoly...I'll do it
Old Nov 13, 2004 | 05:45 PM
speedyrx7's Avatar
Car: 89 IROC
Transmission: 5 SPEED
They used to be one company called Performance Automotive, or PA racing. Jason kept the PA racing name and Vern started ProFabrication. You can get mild steel or chromoly, but the chromoly is more expensive. They're both made basically the same way. Jeff no longer works there and Sam was just a fill-in, So ask for Vern.
Old Nov 14, 2004 | 02:17 AM
Engine: V8
happen to know how much more the chromoly is? pa charges 150 extra
Old Nov 16, 2004 | 06:43 AM
rstanko's Avatar
I did not get a break down of my pricing, but I would say they charged less than $150.00, since I got both the K-member and arms in CM, it was hard to determine pricing.
Overall, for both, mine was about $200.00 more to go CM all the way around.
wigmobile
Feb 26, 2025 02:56 PM
Linson
Sep 21, 2015 01:08 PM
Mdenz3
Sep 17, 2015 08:36 AM
dinkrdsw
Theoretical and Street Racing
Sep 11, 2015 06:58 PM
