front swaybar problem
Old Dec 12, 2004 | 08:27 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
i've got a bit of a problem with my front swaybar and tie rod ends. i cant tell if my swaybar is bent or if there is another explaniation for what is happening. while under the car, i noticed that the tie rod on the passenger side was at almost a 45* angle leaning in a ton and was actually scraping on the inner part of the a-arm, but the drivers side is perfectly fine.
could somebody post a pic from the front of what kind of angle the tie rods are suppose to be at? or tell me how to measure my swaybar to see if its not straight?
i removed the swaybar and tie rods, and bought new rods, and i need to get it al back together so i can see how much of a drop my new springs gave me.
thanks
Old Dec 12, 2004 | 08:33 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
You will probably hear this from several people...but my solution for the swaybar is to leave it off all together. Its not necessary unless you plan on taking corners really fast or race road courses.
Old Dec 12, 2004 | 08:38 PM
jer4251's Avatar
Car: They all sit.
i can seriously run without it? what will keep the wheels fron going their ow seperate way? just the steering linkage?
Old Dec 12, 2004 | 08:46 PM
White91GTA's Avatar
Engine: 5.7L TPI
The swaybar has nothing to do with the wheels. Its whole purpose is to minimize body roll in corners. Yes you can run without it...I have had mine off for about 3 months or so now. The part that you are referring to that keeps the wheels from going off in different directions is the centerlink.
Old Dec 12, 2004 | 08:47 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the sway bar is not connected in anyway to the wheels, the steering linkage is the only thing keeping the wheels from going thier own way. if all your concerned with is drag racing, then take it off.
Old Dec 12, 2004 | 11:42 PM
jer4251's Avatar
Car: They all sit.
i got it all back together and took it for a spin, i really need some sub frame connectors, my body is twisting so bad when i hit the gas. the only other problem im having is with the drivers side front wheel. it leans in a LOT, and the passenger side is straight up no tilt. what would cause this? would an allignment solve this one? it pulls to the right a good bit.
I love the look of the car now. the front tires sit up in the wheel well and the nose is 3-4" from the ground. my only problem is that the inner fender liners are going to rub, ia it ok to run without them? what should i do?
Old Dec 13, 2004 | 09:10 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
yes, an alingment would cure that problem assuming nothing is bent. the measurement is camber, if its leaning in, it is negative, out=positive
Old Dec 20, 2004 | 04:11 PM
mightymaro94's Avatar
no offense but maybe we should make sure he is actually lookin at a sway bar, and not another critical piece of steerin
Old Dec 20, 2004 | 06:36 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I have no front sway bar, personally did'nt notcie any differecne once I removed mine.
The bar directly under the oil pan is the center link, the 2 items connected to the center link on each end are the inner tie rods, then the adjustment sleeve and the outter tie rods.
The pitman arm is on the drivers side connecting the steering box to the center link, and the idler arm is on the pass side connected to the car frame.
HOPEFULLY all of these are still in your car, otherwise your one luck SOB
Old Dec 20, 2004 | 09:34 PM
jer4251's Avatar
Car: They all sit.
lucky for me i know more than enough about cars and removed the correct part. I've cured my allighnemt problem with a hammer and the correct socket, i lifted the car and loosened the strut cap and pulled to the point where the rim was back where is belonged. somehow the cap had shifted over a few inches causing the wheel to lean in really bad. drives straight now.
thanks
Old Jan 1, 2005 | 12:21 AM
Spdfrk1990's Avatar
I took my front sway bar off once and noticed a huge difference but i also have the 36mm bar with poly bushings. I would get a professional alignment of a rack it will drive much better and now wear out your tires.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
db057
Aug 22, 2015 08:17 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
