4.5"BS front 6" BS in the Back. Anyone have this wheel combo?
Old Jan 22, 2005 | 08:39 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I recently got in touch with www.sportruck.com about their Boyd Coddington Smoothie II's. They recommended 17x8's in the front and 17x10's in the back with a 4.5"backspacing and 6" backspacing respectively. My question to you guys is has anyone tried this combination? One problem is you will not be able to rotate the tires. I know the 17x8's will work up front but I am not sure about the 17x10's. I was also considering lowering the car sometime about 1.5". I really like the smoothie II's the only draw back is they don't come in a 9" or 9.5" wheel. If this doesn't work out I guess the original smoothies will have to do. What do you guys think?
Old Jan 22, 2005 | 01:34 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
i have 4.5 in the front on an 8 inch wheel , the 6 on a 10 is right , i know johnnyiroc has 17x10 with 5.75 bs. Id go for the 6 inch . You wont be able to rotate , just get them the two different sizes and dont worry about it .
Old Jan 22, 2005 | 02:42 PM
IROCFAST's Avatar
4.5 is right up front you can really go anywhere from 5.5+ out back, but 6 will keep it tucked under nicely.
Old Jan 22, 2005 | 05:38 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
thats what I was told too for my hotrods....pretty sure Graboid has the same bs as well
Old Jan 22, 2005 | 05:47 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Is a 10" wheel any good for daily driving? What about fitment....any banging needed to the wheelwells? Also what about bending the wheels? I was looking at some softlip wheels with the same combo but im alittle worried about the back being so wide.
Old Jan 22, 2005 | 10:29 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
this is a good post. ive been woundering how much BS in the rear is need to keep the wheel tucked when the car is lowered with a 10'' rim. i got a set of weld prostars 15x10's with a 5.5 bs and i can still fit my fingers back between there and the bumpstop. now if it was moved another .5 youd probably have to trim off the bump stops to what i think just incase kinda thing.
i plan on gettin a set of Foose rims and will be lowerin my car with Dropzone springs as soon as they get here.
Old Jan 23, 2005 | 07:25 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
So these guys with the 10's out back, do you guys know if they have had any rubbing problems?
Old Jan 23, 2005 | 12:27 PM
IROCFAST's Avatar
I had to do some clearancing on the foward part of the inner fenderwell to keep mine tucked under.
Old Jan 23, 2005 | 06:30 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
just so you know kandiedz had 18x10s on his 91 or 2 and had a bs of 6.75 , i know he had to do hammering and cut the bumpstop , the only good thing about going through all the work to fit them is that you could run an 11 inch wide rim .
Old Jan 24, 2005 | 12:05 AM
Kandied91z's Avatar
and they fit right lifted, lowered or ride height.. well a little bit of rubbing when lifted.
http://www.cardomain.com/member_page...&val=1&page=11
Attached Thumbnails 4.5"BS front 6" BS in the Back. Anyone have this wheel combo?-sideprofile.jpg
Old Jan 24, 2005 | 12:07 AM
Kandied91z's Avatar
Old Jan 24, 2005 | 12:57 AM
CrazyHawaiian's Avatar
Car: too many ...
Are you sure they dont come in a 9" or 9.5" wide width? Did you ask them directly? It may not be listed on the website, but when I asked them directly they pretty much said they could make any width I wanted with a $50 extra fee per wheel.
Old Jan 24, 2005 | 01:06 AM
Kandied91z's Avatar
yep they can.
Old Feb 5, 2005 | 07:17 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
would a 6'' backspacing on the rear rims keep the rim in nicely or should i look at about 6.5''? im lookin to get a set of Foose rims 18x9 or 10'' for the rear and was just woundering. right now im tryin to get prices on the rims i want. i dont care if ill have to do a bit of trimming, i gotta fix some rust in the fenderwells anyway.
Old Feb 5, 2005 | 01:01 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i went 5.75 in the back and there was no fit problmes. 17 x 10's and i did the same as you on the fronts and i also got them from sport truck. only p[roblme i had with mine was finding short enough valve stems to clear the bear brakes on the fronts. they way the machine the valve holes does not leave alot of room. its so close i can;t run valve caps. other than that i love the look.
Jeff
Attached Thumbnails 4.5"BS front 6" BS in the Back. Anyone have this wheel combo?-c-documents-settings-jeff
Old Feb 6, 2005 | 08:29 AM
german-motorsport's Avatar
JeffW can you provide the tire manufac./size and the rear fender lip/ ground height?
the car seems not be lowered?
Old Feb 6, 2005 | 02:42 PM
Kandied91z's Avatar
if were lowered much more you would definately have to be careful on the corners.
if you stick to the stock dimensions it works the best, it isn't that hard to modify the inner wells and it's worth the effort overall.
Attached Thumbnails 4.5"BS front 6" BS in the Back. Anyone have this wheel combo?-c-windows-desktop-rear
Old Feb 6, 2005 | 09:25 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys i have a similiar ?i wanna put zo6 wheels on my 89.wat size spacers and wat size bs or mm offset will i need
Old Feb 6, 2005 | 09:29 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i think for the rear you need a 2.25'' and for the front u need a 2'' spacer if i can recall correctly.
Old Feb 6, 2005 | 11:55 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
what kind of rims are those Kandied91z?
Old Feb 7, 2005 | 11:32 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey Jeffw or Kandied i heard the Baer brakes push the rim out like 1/4'' is that true and would most company make a backspacing on the rims that can compensate for that or no?
Old Feb 7, 2005 | 12:43 PM
Kandied91z's Avatar
www.bozeforged.com
depends on your options. mine move about 1/8", 1/4" would be the max i would assume. you can factor this amount in when you order your custom offset wheels or cut your adapters to fit.
Old Feb 7, 2005 | 03:17 PM
tilstad's Avatar
Thanks for the link Kandied. Actually I had just been looking at some wheels over at Boze, only the "stixx", butr can't find any pricing anywhere for these rims, and I didn't get any reply when I sent an email to them either. Do you have any idea what I'm lookin at in 18x9 and 18x10?
Old Feb 8, 2005 | 01:01 AM
Kandied91z's Avatar
retai is $750 a rim but options and dealer prices are different throughout. if you search enough or even try talking with the guys at boze they will usually cut a deal. $425-475 is the norm for them though depending on options again.
Old Feb 8, 2005 | 11:49 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey does anyone know if Foose rims are steel or alumin? becuz im lookin to get a set of the nitrous thrust rims and the company im goin to get the from said there chrome. would that be just chromed alumiun?
Old Feb 8, 2005 | 12:58 PM
Kandied91z's Avatar
more then likely cast aluminum yes.
Old Feb 8, 2005 | 03:04 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay kool thanx.
Old Feb 9, 2005 | 10:29 AM
Avenger007's Avatar
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
So kandied are you running 275s on the rear? They look pretty wide in some pics. Anyone know about TT2 backspacing/offset for a set of 17x9.5 & 11s
Old Feb 9, 2005 | 01:08 PM
Kandied91z's Avatar
on the street 285's and in some pictures they are a 295 dr.
Old Feb 9, 2005 | 01:09 PM
Kandied91z's Avatar
i like the 295's the best.
Attached Thumbnails 4.5"BS front 6" BS in the Back. Anyone have this wheel combo?-c-my-documents-my
Old Feb 10, 2005 | 11:19 PM
Feniks9174's Avatar
Car: 91 Camaro RS Convertible
Engine: 10:1 355 L98
Going with some 17x8's & 10's myself, and I was wondering about the backspacing to make em fit.
Are you guys all using the stock (0 fr, 16 bk) offset as well?
And also, what do you guys think of these wheels:
They're a Billet Specialties SLX45
If someone had the time/desire to photochop these onto a 91 it wouldnt hurt my feeligns either
Old Feb 11, 2005 | 03:17 AM
Kandied91z's Avatar
their ok..
Old Feb 11, 2005 | 10:47 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
they look good,they have that 10 spoke style
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
wruiz
Aug 11, 2015 02:59 PM
