sway bar rubbing bumpstop?
Old May 4, 2005 | 12:52 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Transmission: WC T-5
This is the first of probably many dumb questions for my new ride. It looks like my front bumpstop is rubbing on my swaybar. I believe it is the stock 1LE swaybar. Is this right? Or is this a nonstock swaybar? Any ideas?
On a sidenote, I thought my car would at least have a stock wonderbar, but it has none. I guess I will have to give a call to TDS.
Old May 4, 2005 | 03:27 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Looks like the spacer on your end-link is too short. I believe stock spacer is 2 1/2"
Old May 4, 2005 | 04:08 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Thanks for the reply. I will check that out.
Old May 4, 2005 | 07:51 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
looks like your also missing a bushing at the top
Old May 4, 2005 | 08:21 PM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Here is another pic. The end link does look kinda short to me, but I am no suspension expert. I don't know if it is the original swaybar or the original end link.
Old May 5, 2005 | 03:00 AM
83 Crossfire TA's Avatar
That is definitely an aftermarket endlink… short is up to the sway bar and clearances… you want it with the arms of the sway bar as close to parallel to the ground as you can get and still clear everything. FWIW, it does look short
Old May 5, 2005 | 04:40 AM
Spdfrk1990's Avatar
I would order you some original 1le links since you car is a 1le and all . TDS has them link up top.
Old May 5, 2005 | 08:56 AM
suh weet's Avatar
Car: 1991 Z28 1LE
Engine: LB9
Dang! I just ordered the wonderbar! I should have just got it then. Oh well, maybe I can find something else to buy also!
Old May 7, 2005 | 11:42 AM
JPrevost's Avatar
Car: 91 Red Sled
Those are too short. Notice the angle the bar end is making with respect to the endlink axis. It should be 90*, not just flat with the ground. It should also be apparent that the bar end looks rather out of place with the bushings, a dead give away that it's the wrong length.
I had this problem with a parts store a while back. They tried to sell me on the shorter end link set and I finally told them to ignore what car I had and that I wanted those (pointing to the longer). Just one of my many stories of parts store idiots.
MrPackstin
Oct 25, 2017 08:09 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
