question on sway bars
Old May 4, 2005 | 10:17 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i searched, but maybe not enough........
what cars (camaro or firebird) came w/ the thickest sway bars? a guy i work with, his brother owns a junkyard and has a Z or two laying around. i want to find something better than what i have now to put w/ some poly endlinks. any help here? thanks a lot!!!!!!!!
Old May 4, 2005 | 10:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The thickest bars were the 36mm hollow front and the 24mm solid rear. They came on some Z28 and WS6 cars.
Old May 4, 2005 | 10:43 PM
drdave88's Avatar
Engine: 6.0L
are there solid 34mm sway bars? and if so, are they better than the 36mm hollow bars? what did the 34mm solids come on?
Old May 4, 2005 | 10:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I believe there are 34mm solid bars as well, and they're comparable in stiffness to the 36mm hollow bar. It's hard to tell what size is going to be on a given car it seems. It's probably best just to just look for performance-optioned newer cars and measure what they've got.
Old May 4, 2005 | 10:52 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Apeiron pretty much said it, however I'm fairly sure that the 36/24 combo was limited to 1LE Camaros and WS6 Pontiacs.
I'm running the 36/24 combo and it's wonderful
drdave88's Avatar
Engine: 6.0L
alright, ill check out the iroc-z and z28 cars in a yard near me. thanks.
Old May 4, 2005 | 10:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Z28s too, AFAIK.
Old May 5, 2005 | 02:39 AM
83 Crossfire TA's Avatar
Late Z28’s, the early ones with the “good” suspensions got 32’s in the front.
The factory 34’s are hollow, but there were aftermarket solid 34’s and I believe 36’s.
FWIW, if someone has one I’ve been trying to find a hollow 34… seems like 36’s are much easier to come by then 34’s and if someone finds a 34 no one (else) wants it so they get junked.
Old May 5, 2005 | 11:57 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
You can find hollow 34mm bars on the front of late RSs with 16" wheels. They generally got the F41 suspensions. Or at least my RS cam with a hollow 34mm.
Old May 5, 2005 | 03:09 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
get with www.p-s-t.com and get nice fat solid ones,i love mine....
Old May 5, 2005 | 11:47 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Yep...my RS came stock with the 36-24-(36? ) setup
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
