Let's decide this once and for all...
Old May 7, 2005 | 07:39 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Stock suspension on a 1992 RS with 16" wheels and F41 RPO code. What size sway bars does it have? I have searched and have seen everything from 32-36 solid/hollow front, and 22-24 solid/hollow rear. Which is it? Do they have the fast ratio steering box or not? My '92 has the 16" wheels and F41, but the steering feels awfully loose. It does look like it has a pretty big sway bar up front though.
Old May 8, 2005 | 02:00 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Never made hollow rear swaybars. Your car probably has either a 34 or 36mm from what I've been hearing lately.
My car had the 36/24 combo, but still felt somewhat loose. Replace your swaybar endlinks and mount bushings with poly stuff, and you'll notice a HUGE difference. Also, buy a wonderbar, another nice addition. Shocks/springs don't hurt either, and neither does a strut tower brace.
Old May 8, 2005 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Nothing that people "decide" here will have any effect on the size of your sway bars.
Go measure them. A Crescent wrench right next to the bushings, and a measuring tape with mm, is all you need.
Old May 8, 2005 | 06:26 PM
Car: 1997 Corvette
I got so caught up in my poly bushings rant, I forgot to tell him to measure!
Undersizing your bushings 2mm or so doesn't hurt anything by the way. For example, I'm running 22mm bushings on 24mm rear bar and 34mm bushings on 36mm front bar. I actually think that's the better option
Old May 8, 2005 | 06:34 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Holy crap, I saw a car with 'f41' on the bumper at the JY.. What does f41 mean, exactly?
Old May 8, 2005 | 07:55 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
https://www.thirdgen.org/techbb2/sho...&highlight=f41
And a search would yield everything.
Also my 91 f41 has 34 solid front and 21 solid rear.
Old May 8, 2005 | 09:54 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Actually, I'd size the bushings to match the bar. You want a snug fit...but not binding. Also, pay the extra for geasable ones....poly bushings are noisy unless you keep them lubed.
Old May 14, 2005 | 08:38 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
My 91 ta with f41 susp and I just replaced bushing and endlinks the front was 34 and rear was 24. But I think gm used what ever they had over the years so the sizes very in the 80's. Not sure if they stayed consistent during the 90's. Maybe others will chime in with what they have on 90's cars to see of there is any consistency. But the only true way to know is measure with calipers or mic's.
Old May 15, 2005 | 09:43 AM
Car: 1997 Corvette
I haven't had any issues with binding on my front or rear bar yet. I lubed the rear bar mounts with synthetic wheel bearing grease and did the front bar mounts with the included lube (felt more like glue than lube). Reason I undersized them was #1, 36mm bushings are insanely expensive, #2 22mm bushings could be found in parts store the day I decided to do the rears, and #3 I've heard these mounts can "cold-flow" and expand, but usually won't expand more than 1-2mm, so I figured by undersizing them a bit, they'll expand out to the right fit
Old May 15, 2005 | 11:14 PM
Spdfrk1990's Avatar
My sisters 92 f41 had 34 hollow front and 21 solid rear.
Old May 19, 2005 | 08:04 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
[Edited for content] N/M, no need to rant...
It should be a 34/21 like mine..Does this help:
https://www.thirdgen.org/techbb2/sho...threadid=59687
Ed
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
