Tip on when replacing motor mounts
Old May 22, 2005 | 07:11 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
Hey guys I just put moroso solid motor mounts on my car, and if u ever have replaced a motor mount in a third gen f car before you know its not the easiest to do.
I got all the bolts out with a 15mm(if i remember right) a universal and a 12 inch extension and a wrench, except for one a had to saw off (top passenger bolt in the front).
Now when i reinstalled them instead of puttin the bolt down and trying to thread the nut on (which would have been near impossible) i put the bolts up thru the frame and the nuts on top.
I got all but one bolt up thru with the same tools i used for the removal, but the last one (same one i had to saw off) i couldnt for the life of me get it up through, i tried for about 20 minutes at least with the socket universal and extension combo, but then i dropped the bolt inside the frame, and I reached for my handy Telescoping magnet on a stick to retreive it. Well then i got the idea, hey maybe this will be able to get the right angle and get it up through, and bam, it took 4 seconds. lol.
If u dont have one of those tools i suggest getting one, they really are handy, and now is my favorite tool
Old May 22, 2005 | 09:46 PM
CaysE's Avatar
This is just my opinion, and I'm glad you got everything to work right, but sawing bolts and putting them back in upside down doesn't exactly sound like solid advice.
Old May 23, 2005 | 12:40 AM
Borsty's Avatar
Car: 89 Trans am
i couldnt for the life of me get the one bolt out, id rather spend 2 minutes sawing it off instead of messing with it for like a half hour which i did, i got all new bolts nuts and washers anyways.
puttin the bolts up thru the frame instead of down i dont see the big deal, and besides my friend with a 454 BB in his trans am did the same and its worked fine for him.
Old May 23, 2005 | 02:12 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
you dont have to worry about sawing bolts OR putting them in upside down for something like that... you just have to know when to not do something like that...
good idea though, i need to change my mounts soon.
Old May 23, 2005 | 08:46 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
Now what happens when the bolt and nut loosens and all of a sudden the mount slips and does serious damage? This is why you put them from the top down. That way if the nuts loosen most likely the mount wont move like it would without a bolt in there.
Old May 23, 2005 | 09:32 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It doesn't matter if they are up down or whatever ..
if they come loose they come loose, the motor will still move around, and it will fall apart no matter what .. just use a little lock tite
Old May 23, 2005 | 05:35 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
yes it does. yeah the motor will move a little but if they are put on the topside you wont loose that bolt if for some reason it comes loose.
Old May 25, 2005 | 02:32 AM
83 Crossfire TA's Avatar
How do you like the solid motor mounts?
Old May 25, 2005 | 10:15 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
i havent run them in the camaro yet as it is still in its slow build up stage. when i had the el camino they made the motor sit a little bit higher. that was my only complaint.
now there has been much talk about solid mount, engine and tranny, putting stress on the transmission case. thus, resulting in a cracked tranny or broken mount. i have never seen this happen but it can.
Old May 25, 2005 | 12:02 PM
Borsty's Avatar
Car: 89 Trans am
actually i ended up taking them off and putting normal ones on, the people helping me (older guys who know their stuff) said it was a very bad idea in a daily driver.
so if anyone wants moroso mounts for a 3rd gen with bolts gimme a pm.
Old May 25, 2005 | 05:02 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
ive seen that happen, always run a poly or rubber mount somewhere. either the motor mounts or the tranny.
Old May 26, 2005 | 12:04 AM
Huh… I’ve been wondering about solid mounts in 3rd gens. I’ve installed them on a couple of other cars and never really noticed significantly more vibration or had any issues. In some cases you do notice the front end being somewhat stiffer, since the engine block suddenly becomes a solidly linked part of the front suspension
Old Dec 11, 2005 | 01:05 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
I was thinking of putting some in my car.. its gonna be a daily driver....so i guess it is not recomended for a daily driver?
Old Dec 11, 2005 | 05:41 PM
ckeene502's Avatar
i ran solid motor mounts in my 83 camaro with a poly trans mount. i also had tubular k member and art morrison coil overs with tubular a arms. never had a problem with vibration but it was not a very strong motor.
Old Dec 14, 2005 | 08:49 AM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
I am just going to put poly ones in. Is there and easy were of getting them out?
Old Dec 14, 2005 | 09:58 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i put them on my daily driver and i love them....but i also enjoy the vibrations i get from knowing my motor is on and running well.
it also helps with the cars reaction time.
Old Dec 14, 2005 | 11:44 AM
Borsty's Avatar
Car: 89 Trans am
it was a big pita but its doable if u know wtf your doing in about and hour if its your first time.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
