Best 60 ft times with stock torque arm
Old Jun 4, 2005 | 11:26 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
How quick of a 60 ft time have you run with a stock torque arm?
Old Jun 4, 2005 | 01:13 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
2.25
Anyone better than that? lol
Old Jun 4, 2005 | 01:28 PM
Car: 1971 Camaro
Engine: 427
Originally posted by DuronClocker
2.25
Ouch! Man, your set up sounds pretty good. Why so slow? Not trying to offend you, I am guessing some serious lack of traction on street tires?
Old Jun 4, 2005 | 02:46 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
1.9 with a stock 305 TPI 5 speed, stock rear suspension and 3.73s.
Now with the 350, 6 speed, 3.42's, Spohn torque arm bxed poly LCA's and PHR 2.2 :squint:
Then again I added about 150 ft-lbs of torque at the wheels
Kat
Old Jun 4, 2005 | 07:42 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My car went 1.703 with no effort. Not only do I have the stock torque arm, I have stock everything even the front sway bar. Next time out I'm positive it'll hit 1.6x's
Old Jun 4, 2005 | 07:45 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Old Jun 4, 2005 | 10:52 PM
Car: 1997 Corvette
Eh, I had only had the car for a month and it was my first time to the track. That was just with my SLP cat-back, street tires (Kumho 712) and stock everything else. This year I hope to be in the 1.8s or so and running 13s without the juice (still have engine work being done not in sig yet).
Old Jun 5, 2005 | 03:16 AM
83 Crossfire TA's Avatar
1.71 on radials (GSC's) and a stick
1.81 on radials (old Gatorback ZR's) and an auto
Old Jun 5, 2005 | 08:39 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
10.90streetcar is constatly in the 1.4? range on the stock stuff. He does have the anti-roll bar installed though.
Old Jun 5, 2005 | 10:16 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I pull 1.9's all day long with a stock torque arm. This is done with a complete street setup, full weight, cheap street tires (Kumho 711's), ~35psi.
Old Jun 6, 2005 | 03:23 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
11.03 at 124 mph with crappy 1.57 60' Do you think a new torque arm will solve the wheel hop I have out of the hole? I'd like some responses. My 60' went to 1.65 after I installed qa1's
Old Jun 6, 2005 | 09:50 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
LCA's and bushings will cure some wheel hop. 1.57 60ft wheel hopping? thats umm.. pretty strong. I have the Spohn adjustable torque arm and Hotchkis LCA's and have no wheel hop with 1.51-1.54 60ft ranges.
Old Jun 7, 2005 | 08:20 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
yes, I have video of the front end lifting and coming right back down again. I am guessing it is a torque arm thing since I have lca's already. it's the oddest ocurrance. would horizontal movement of the torque arm say .5 inch make it wheel hop?
Old Jun 7, 2005 | 10:15 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I pulled a 1.66 short time in a manual before my rear broke. The TQ arm is bent all to hell. I really need a picture of that.
Old Jun 7, 2005 | 10:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
1.6s.... but my stock TQ arm is from a 4thgen.... so i donno if that counts.
Old Jun 7, 2005 | 12:12 PM
Stevo's Avatar
Car: Pair of 92 Z28s
2.066
street tires, everything.
Old Jun 7, 2005 | 12:25 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
2.054 on street tires and bone stock suspension all around...in serious need of tuning!
Old Jun 8, 2005 | 11:29 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
If the torque arm is not tight, like where it slides into the trans mount, you could get some rear end chatter causing it to wheel hop. With those 60ft times, I would go with something stronger. One that bolts to the crossmember and not one that slides into a little bushing.
Old Jun 9, 2005 | 03:29 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
you could try relocation brackets and see if those help
Old Jun 10, 2005 | 01:14 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
You can go fast on stock suspension.
http://www.1320hp.com/1320promo.mpg
Stock LCAs, torque arm, and PHB.
Old Jun 10, 2005 | 01:18 AM
nape's Avatar
Did you try to play with the dampening on the QA1s to see if you could get the front end to rise slower? Sounds like you've got too much weight transfer and you're blowing off the tires.
Old Jun 10, 2005 | 08:26 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Yes, those are on my list of items to get.
Old Jun 10, 2005 | 08:29 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
with just building a house I am a little short right now. But my plans are to get a spohn TA or the BMR track pac. Hopefully that with lcrb's it will get me into the high 10's with 1.50 or lower 60' times.
Old Jun 10, 2005 | 11:55 PM
brutalform's Avatar
1.65, BFG Dragradials, stock torque arm.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
Thirim
Aug 9, 2015 06:19 PM
