HELP!!! Front coil spring replacement
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I have a '88 Trans Am GTA and I replacing the stock front coil springs since the dumbass who owned the car before decided to heat the old ones up and ruin them. I already have the old springs off and I am trying to get the new ones in. I have tried both styles of spring compressors and both of them are too big. When I go to compress the spring the threaded bolt of the compressor starts sticking out way above the top of the spring thus making it impossible to install on the car. I have already tried taking the control arm off, placing the spring it and and jacking it up in to the car, this did not work because the car itself just starts going up. I live in an apartment, I have an air compressor and air tools but I am alone with no one to help me. Please give me some advice or call me at 512-297-8842 I am losing my mind here. Thanks, Jeff
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
There is no decent spring compressor that works on these cars. You'll either have to do one of these things:
Cut the bolt shorter on the coil spring compressor...not much of an option with a borrowed tool.
Put 3 or 4 inches worth of washers, pipe, or other sort of spacer on the head end of the bolt before you run it through any of the clamps. Then when you install, let the excess lenght of the compressor bolt stick through the hole in the bottom of the a arm.
A third way is a little hard to describe without a picture. Not my idea, and I've never tried it, but there was a guy who posted a thread with the idea, and a picture (i searched, coudlnt' find it). He made a small, round, steel plate and drilled a hole in the center the size of the compressor bolt (basically he made a BF washer). Then he put the bolt through the BFW, then through the hole in the a-arm, then the spring, and last, into the spring clamp. When he tightened it down, it pulled the coil tight against the a-arm.
Found it...
https://www.thirdgen.org/techbb2/sho...t=coil+springs
I've never tried it that way, as I haven't had reason to do a spring job since I read that post, but that sure as **** looks to me like the way to do it.
Engine: LS1 V8
Thank you for the posts and the info Black. After about 5 more hours worth of trials, frustrations, and sweat I ended up putting the crapped out bent ones back on. I don't have access to anything like a saw or scrap metal. To perferctly honest today has extenguished the flame I hold for these cars. Everything is so hard on 3rd Gens. No tools work for them, hardly anyone at any auto parts store knows what you are talking about when you try to get help, GM does not care about 3rd Gen's anymore, and just in my personal situation I do not have the proper space and resources to do hardly anything more advanced than an oil change. Thank you again for your help. -Jeff
Car: 1990 firebird
Engine: 3.1 v6
damn man that sucks, i feel for you. I was pissed and cursing when i was trying to do mine. I gave up and took it to a shop. 60 bucks later and vuala. the springs won
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the problem is you're using the wrong tool.
the spring compressor you need uses two hooks on one end to grab the top of the spring, and sticks thru the A arm... a forked plate under the A arm slips in and lets you tighten the spring to the arm...
i spent 20 hours in my apartment parking lot last weekend doing the same thing..... except i have no power, so no airtools for me
i had to crank it down by hand...... made a 4 hour job take 20.. lol
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Here's a link to someone else's creativity that I used and worked great.
http://pg.photos.yahoo.com/ph/tarami...ac.jpg&.src=ph
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
dang...I borrowed a set of spring compressors from a friend and I was able to do mine in @ 2 hours...both sides....
Just need to be sure and put the top set of clamps as high as possible and the lower set as low as possible like within one coil of top and bottom.....
Course then I had to REDO them as I didn;t get them seated in the top mount properly
that took about an hour
that took about an hour Member
Engine: 305TBI
Transmission: AUTO
ahhh come on guys....
it's not that hard to crank them down using a socket...
I'm 58 and did it not once but twice on both sides.....
and NO I didn't walk to school 15 miles uphill both ways
I think I would have been very leery of using a power tool.......loose the feel of the spring tightness and slippage.
The link lo-tec posted is a VERY good idea
Engine: LS1 V8
I have read through everyone's posts not to mention other posts on the site and it seems everyone has encountered different levels of difficulty with stock spring replacement. I have several questions. First, the interal compressor, once you get the spring mounted and the arm bolted to the spindle, can you get the top knuckle/claw out of the spring through the coils? I test fitted mine and it would not fit through the bottom hole in the a-arm. I have seen the pictures of the compressors with their bolts cut, using a large washer on the bottom of the a-arm, and using the piece of pipe to take up some of the length. I honestly never thought of using the pipe nor the washer. If I get the courage up to do this again I will try it and report back with my success.
Car: check
Engine: check
Transmission: check
The proper method of spring replacement is to remove the two A-arm pivot bolts and drop the inner portion. This is from the factory service manual. No spring compressor is required. The ball joint stays connected.
It works rather well. I've done many a vehicle with this method and it is fast and easy. The factory manual shows a special bracket to cradle the lower A-arm. This isn't always required. I use a hydraulic floor jack and hook two of the lift plate tabs under the edge of the A-arm, right between the pivots.
Put a little(!) tension on the spring, then check it's placement. Make sure it is properly seated in the upper seat, then check the hole/spring-end placment in the lower seat. For safety place a chain through the coils about halfway up and then down through the hole in the A-arm. Bring chain around and bolt ends together.
Slowly jack A-arm up into place. Once either hole is lined up place a phillips head screwdriver through that hole. Then move the other pivot into place and put another screwdriver through that hole. Can now use the screwdrivers to better align a hole and quickly slip the bolt through. May need to tap it in with a hammer.
Do the same for the other pivot, torque it all down, and you're done. Take your time, think about what you are doing, and it goes quickly with little fuss.
RBob.
RBob.
Car: 91 Camaro Vert
RBob.
RBob.
you have to bolt the pivots in, undo the strut, and do it that way.
the spring compressor i use holds the spring to the A arm. works well.. no tool modding needed, and if you're smart about it, the springs always in the pocket or otherwise shielded when its compressed, so theres less danger..
this method works great on everything except the PA racing and Profab tubular Kmembers.... the crossbar is in the way of the a arm , so it cant come straight up.
Car: 91 Camaro Vert
Originally posted by Lo-tec
It can't go straight up, but you can use a prybar or two to guide the arm up using the jack method.
i tried it, and i didnt feel comfortable with it.... too much movement under tension...
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Jeff, here's how I did mine. The pic linked earlier was from my album:
http://pg.photos.yahoo.com/ph/tarami...r=5792&.src=ph
HTH....
Ed
HTH....
Ed
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
That's a good idea Ed....I just used about 3" worth of large washers on mine. The first compressor unit we had (just like Ed's) my brother broke...some of the threads on the center threaded rod stripped and the top hooks of the compressor flew off......I wasn't there when it happened......
Be careful!!
Be careful!!
Car: check
Engine: check
Transmission: check
Originally posted by Anniversary-Z-man
. . .The first compressor unit we had (just like Ed's) my brother broke...some of the threads on the center threaded rod stripped and the top hooks of the compressor flew off......I wasn't there when it happened......
Be careful!!
Be careful!!
With the jack method you are several feet from the spring. And it is chained to the lower A-arm as it is being compressed. Once a pivot lines up a quick reach underneath and a heavy phillips head screwdriver is in place. This acts as another safety.
During the time the jack is compressing the spring it is easy to back off. If something doesn't look right, a simple twist of the handle and the tension is off the spring.
To quote Z-Man "Be careful!! "
RBob.
TA8487
Aug 11, 2015 09:02 PM
body, coil, factory, front, gen, installation, installing, replacement, spring, springs, thirdgen, tool, yahoo
