Another choice for sub frame connectors
Old Jun 12, 2005 | 09:36 AM
e-man's Avatar
Car: 89 formula
Engine: 383
http://www.umiperformance.com/2400.aspx They look pretty good. What do you guys think?
Old Jun 12, 2005 | 01:23 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ok, but tubular is the way to go. Got a weight on them?
Ed
Old Jun 12, 2005 | 03:48 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I'm willing to bet that they are heavy as hell.
Kat
Old Jun 12, 2005 | 04:58 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The SFC's look to be well-designed. And the price is very competitive at $200 with powdercoated finish.
I would be curious as to their weight as well. Spohn's first design used square tubing and that was considered a decent product.
Ed, do you have the weight figures on the present Spohn tubular design? One of these days I want to add them to my '92.
Old Jun 12, 2005 | 05:27 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
im gonna get those, thanks for the link , i dont like the spohn tubular ones and doesnt it even say on umi website that since their square they are better torsional ridgidity . ? or did i read wrong.
edit :
When strength is a concern, square tubing has greater torsion resistance over tubular designs. Subframes do not effect ground clearance and weld-in style requires no bolts to tighten ever and less chance of flex compared to bolt-in types.
Our subframe connectors for the third generation F-Body is, by far, the strongest set-up on the market. This unique design utilizes a 3 piece set-up, allowing (3) major weld points through out the chassis of the vehicle.
Old Jun 30, 2005 | 07:56 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I looked at those at the GM Nationals, and was very impressed. They're quite beefy. Yes, they're heavy, but that's the price you pay for strength.
My question is whether they'll work ok with LCA relocation brackets.
Old Jun 30, 2005 | 11:09 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
LCA relocation brackets go on the axle, not the frame.
Old Jun 30, 2005 | 11:49 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
has anyone bought these and have them on their car? ive been thinking about buying them for a few weeks now.i just wanted to know how they compare to the otheres that are out there.
Old Jun 30, 2005 | 01:07 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
If you are looking for something that is designed just as well if not better and do not weigh a ton, you might want to check out Kenny Brown. They get my vote.
http://www.thunderracing.com/catalog...&vid=6&pcid=36
Note: If you are looking for a lower price I know of one place but it is not that huge of a price difference. I think it would boil down to shipping rates. PM or email me for details.
Old Jun 30, 2005 | 01:57 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
The spohn sfc were almost 25 pounds and the lca were about 5.
Old Jul 3, 2005 | 02:00 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
Those don't look to bad need to find out how well they fit and what the weight. Keep us posted on how well these work
Old Jul 10, 2005 | 11:55 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
what about verts?or will they work on non verts like most
Old Jul 11, 2005 | 12:24 AM
CrazyHawaiian's Avatar
Car: too many ...
I'm with soulbounder, I got the KB Super-Subs, excellent build with tabs and very light for SFC's.
Old Jul 11, 2005 | 12:39 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Evidently UMI Performance isn't aware of the boxed sheet metal reinforcements that were installed behind the GFX on ASC (aka "factory") convertibles. No these would not fit a convertible unless you removed these reinforcements, (which I don't recommend).
Lon
Old Jul 11, 2005 | 04:16 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
[i]When strength is a concern, square tubing has greater torsion resistance over tubular designs.[/B]
Someone please correct me if I'm wrong, but I'm under the impression that round tubing offers better torsional resistance. Square tubing provides better bending resistance.
Old Jul 12, 2005 | 07:42 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
a roll bar makes a good sub frame connecter ... IMO... tao
Old Jul 16, 2005 | 10:07 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
so what's better, sphon or umi sub frame connectors?
Old Jan 24, 2007 | 07:52 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
2" round tube, .1875 wa:
3.61 lb / ft, moment of inertia 44.82
(most compact, least torsional strength)
2" square tube, .144 wa:
3.61 lb / ft, moment of inertia 45.42
(better torsional strength than 2" round, but not as compact)
2.828" round tube, .126 wa: (same OD as the distance across the corners of hypothetical 2" square):
3.61 lb / ft, moment of inertia 46.72
(better torsional strength, depending on what room you have, may be as compact as 2" square)
2" square tube, .1875 wa:
4.60 lb / ft, moment of inertia 57.70
(best torsional strength, extra weight, just as compact as other 2" square)
Given equal section areas (=> equal wt. / ft), a tube gets torsionally stronger as you move material further away from the axis. The 2" square .144 outperforms the 2" round because the material making up the corners and most of the sides is further away from the axis. Likewise, the 2.828 round is better than 2" square. So, if you have a square-ish channel to run your subframe connector in, you should make the subframe connector as large of a square (or rectangle) as you can fit in the channel, and then optimize the wall thickness to get the strength you want. If the channel is round shaped, then you won't be able to fit a very big square in there, and will be losing out on torsional rigidity for the material that you are using.
The connections to the body are pretty important too. A 2" solid bar with poor connections won't help much.
83RDRACR
Mar 26, 2016 08:13 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Lanz06
Sep 14, 2015 07:16 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
WickedBowtie
Sep 11, 2015 11:24 PM
