Nailed a curb... pretty hard
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Man, am I bumming. I'm too old to be making these kinds of mistakes.
Anyway, I hit abount an 8 inch curb going around 10-15 MPH. A large chunk of the rim was taken out (see below). I was able to pull the car off the curb and straighten it out on the road. The ground effects took a hit (expected that) and the alignment is totally wasted. The car is creaking when you turn right in a manner it didn't before and the passenger's side wheel is rubbing on the interior of the wheel well.
What else could be wrong? Gimme worst case so I have an education when I get the repair bill. I'm hoping it is just an alignment on top of a new set of rims. I've never been that lucky.
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Balljoints, check them for excess freeplay and see that they aren't wasted.
Spindle, look to see if there are any stress lines showing through the old road grime, signs of it slightly cracking or flexing. I'd take off the rotor and take a good look at the bearings and where they mount.
The rod for the strut. It might be bent....
Strut mount
Inner tie rods were already said.
Yeah, that's about most of the stuff you can mess up hitting a curb.
Strut mount
Strut mount
Strut mount
Nail on the head.
Travis... can you think of a better excuse for new wheels?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
that would be a better excuse.
Update:
Spindle
Baljoint
Control Arm
Tie rods
Alignment
There is a quick 1000 bucks for you.
Spindle
Baljoint
Control Arm
Tie rods
Alignment
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Holy ****, that's nuts.
That's maybe $350 in parts if you did both sides...
Car: 91 Camaro Vert
Update:
Spindle
Baljoint
Control Arm
Tie rods
Alignment
Update:
Spindle
Baljoint
Control Arm
Tie rods
Alignment
Spindle -50
Baljoint - 12 for mine, but lets say 15 and get both
Control Arm - any more then $25 is a ripoff
Tie rods - $15 each
Alignment - $between 50 and 85...
thats still only $205....
Originally posted by MrDude_1
Spindle -50
Tie rods - $15 each
Spindle -50
Tie rods - $15 each
Car: 91 Camaro Vert
Pick and pull?
Pick and pull?
then again, you're in cali, so who knows? lol
edit:
and of course the balljoints and tierod ends are new.. only things used are the a arm and spindle.....
GM used the same joints and ends in ALOT of things, so they're really cheap.
TheTraut88
Sep 7, 2015 05:22 PM
