4 gen rear end in 3 gen - what wheels
Old Jul 8, 2005 | 11:54 AM
Paul_82TA's Avatar
Car: 1982 T/A
Engine: 305 carbed
Transmission: TH700
Hi to everyone on the board.
I bought 1982 TA 305 carbed a month ago or so.
Last owner did a swap for a 4rd gen rear end (3,42 LS), which is great but... now my wheels and tires stick outside the car , and it seams to bother the police. I've got stock 16x8 rims with 255 rubber.
So I need to buy new rims with bigger ET
My question is what is the diference in lenght in 3gen and 4gen rear end. From what I know the maximum backspacing in 3gen is around 5.85".
Since I got a bit wider rear end what ET should I look for if I want to put on 17x8 ( will wider fit at all - witout sticking outside ).
thanks in advance
Paul
Old Jul 8, 2005 | 03:03 PM
erummel's Avatar
Car: 92 Z28
Engine: aint got no engine right now
Transmission: need one of those
When you buy your wheels just by the rears for use on a 4th gen rear.
Old Jul 8, 2005 | 04:25 PM
Paul_82TA's Avatar
Car: 1982 T/A
Engine: 305 carbed
Transmission: TH700
the problem is that 4gen is wider then 3 gen so i got less space. in other words I have to buy wheels with bigger offset I think.
What is the standard offset in wheels for 4gen ?
Old Jul 8, 2005 | 05:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
all you need is regular 4th gen wheels, with them the wheels will look like it did before(not sticking out at all)
Old Jul 9, 2005 | 01:43 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i think that the forth gen is 2-4 inches wider then the 3rd. not sure though.
Old Jul 10, 2005 | 05:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
4th gen rears are rouhgly 4" wider than a 3rd gen wheel. You will need to run 4th gen/vette wheels or live with your stockers giving your car that "skateboarding" look. LT1 and LS1 rears are not the same width though. IIRC the LT1 rear is a tad wider (1") so some people use a 1/2" spacer if they run LS1 wheels. I just installed my 4th gen rear but forgot to take pictures of the width difference.
Old Jul 14, 2005 | 01:44 PM
Paul_82TA's Avatar
Car: 1982 T/A
Engine: 305 carbed
Transmission: TH700
I would leave the "skateboard look" - as you called it. But the reason I need to do something about it is that twice in one week cops wanted to take my papers away for that. So 4 gen/vette wheels is a good option. Will i fit 17x9.5" under there ? and what Offset I should look for then.
FE those:
Torq-Thrust II 505 Series Wheel
back :
Size: 17'' x 9-1/2''
Bolt Circle: 5 x 4-3/4''
Rear Spacing: 7''
front :
Size: 17'' x 8''
Rear Spacing: 4''
Old Jul 14, 2005 | 03:29 PM
erummel's Avatar
Car: 92 Z28
You had to be doing something else other than driving a car with wheels protruding from the wheel wells to get the attention of the police. And you must be gullible to believe that you could loose your license or registration for wheels protruding from wheel wells.
Something does not add up here.
Old Jul 14, 2005 | 03:57 PM
Paul_82TA's Avatar
Car: 1982 T/A
Engine: 305 carbed
Transmission: TH700
Nope, The rules in Poland are diferent, you cannot have protruding wheels, they specifilcy said that I have to change that or they will take my registration, not lincence. Im not the only one with problems like that here. One of my friends had to do something like that to take cops of his back.
my wheels are situated wider - around 1-1.5" than those on the picture.
another example - one friend just finished a car - and to have some peace on the road from the cops he had to do something like this
http://www.astercity.net/~airwolf/ph...robert40hs.jpg
but I dont want to change the shape of the body.
Old Jul 14, 2005 | 06:23 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
wow your police are pretty crazy strict.
Old Jul 14, 2005 | 06:54 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
a friend of mine here (in Wisconsin) had crager ss rims that stuck out like 2 inches on each side... got pulled over almost every day JUST for that.. lol, that was a lot sticking out tho
Old Jul 15, 2005 | 10:37 AM
erummel's Avatar
Car: 92 Z28
What dumba-s-s reason is given for that?
BTW, looking at your pictures it does not even look like your rear wheel is protruding past the lip of the fenderwell. Maybe it is just the picture but it looks likes like your wheel is just in line with the lip.
Old Jul 15, 2005 | 10:57 AM
Paul_82TA's Avatar
Car: 1982 T/A
Engine: 305 carbed
Transmission: TH700
this black bird is not mine. I got around 1.5" wider wheels setup on each side. So you can see that they stick out from a bigger distance.
The reason they give me : You will splatter mud and stuff on the car behind you, and that could result in traffic accident.
beacouse I cant just go to autoshop and try out few diferent rims and rubber setup, all rims in europe have diferent bolt setup, and I have to buy rims in US and I want to make sure they will fit.
So does anyone know will 17" x 9.5 fit in the back ( without sticking out ) ? or do I have to buy 8"
and do I have to buy spacer for front to put 17" x 8 ??
Old Jul 15, 2005 | 11:02 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You just need a wheel with the proper backsapcing. 3rd gen wheels have a tremendous amount of back spacing. You can run an 11" wide wheel if you get the proper spacing.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IroczFan
Oct 6, 2015 10:13 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
