Holy Wheel-hop batman!
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Well, just got the 3.73's in! Here are the specs
Motive gear
Motive installation kit
Eaton Posi Unit
Moser Hardened axles
Mac girdled rearend cover
Wonderful! Finally got them in... been sitting in the garage for four or five months..
I have some questions tho.. as you see with the post name, I HAVE A ****-TON OF WHEEL-HOP! What all would be recomended suspension upgrades that would help me get the power to the ground? I was thinking about the following:
Spohn Adjustable torque-arm/crossmember
Shocks/struts
Lower Control arms
Adjustable panhard rod
Springs - This is another question.. Im thinking about getting air bags... What kind of effect do they have on getting my tires to hook better/eliminate wheel-hop? What kind of effect do they have on handling? As apposed to Eibach Prokit or Sportlines?
Also, I know my speedo is now off.. I dont have money to grab the speedo gears right now, so i was wondering if someone would know what the difference would be between 2.73 and 3.73.. just so I know what speed I am going until i can grab some speedo gears (couple weeks).
Sorry its so long!
Thanx for the help
Motive gear
Eaton Posi Unit
Shocks/struts
Lower Control arms
Sorry its so long!
Thanx for the help
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Holy calculations Robin!
I was at George Barris' auction a few weeks ago
Here's a link that will help you. Tire radius is 12.85. The 700r4 gear ratios are lower on the link page.
https://www.thirdgen.org/newdesign/t...ulations.shtml
I was at George Barris' auction a few weeks agoHere's a link that will help you. Tire radius is 12.85. The 700r4 gear ratios are lower on the link page.
Car: 1990 Camaro IROC-T
Engine: L98 Turbo (GT40)
Transmission: THO400
Axle/Gears: Forged axles, 3.23 rear
Hey dude... have you got any full sized pics of your car. Its spot on to what I'm doing to mine. Red, black cowl hood.
Car: 1987 Iroc-Z
Engine: 355
lol
actually, thats how i bought it.. The paint is faded/chipped really bad and the cowl hood is just the black gelcoat that harwood sends it in.. The car looks like total hell man, trust me.. and in a few weeks its gonna be all black with blueberry pearl in the clear coat..
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Hehehe...I saw the 60's style batmobile going down the street a few weeks ago. I was stunned for a moment.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'll help a bit. a set of LCA relocation brackets welded to rear housing will help more than any other single modification. even with stock components. all the other stuff you have listed is good, but the LCA relocation brackets and maybe boxing your stock LCA's would probably do the trick for now. i know how money is tight so.....
Car: 1987 Iroc-Z
Engine: 355
i just need to find someone who will weld them for me
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
wheel hop
I had that problem and replaced stock arms and panhard bar with lakewood products and solved that problem. Spohn torque arm is worth the money(600) in my book. No welding all bolt in stuff.
Engine: 7.0L
the relocation brackets work wonders, trust me. here is what i've done to my rear suspension, probably have all of $150 in it:
STOCK torque arm with poly bushing up front
STOCK lca's that i boxed using 14ga steel
spohn non-adj panhard rod
spohn lca relocation brackets.
i have had NO problems with wheel hop and with my 275/60/15 M/T ET Street Radials and 4.10s, traction isn't an issue either, have made several consistant 1.75/1.76 60' times.
edit: spohn lca relocation brackets are only $65...MORE than worth the money in my honest opinion. way cheaper to do it my way than to spend bookoots on tubular replacement pieces. the only reason i did the panhard rod was cause my stock one had been bent. if i had the stock one, i'd have just boxed it in.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
HEY!!! WTF!!!
since when does nova have a white car???? and a better timeslip??? geez, I gotta find some of your recent posts here....
Car: 1982 Trans-Am
nevermind, found those posts... all this in a new car?? sheesh! Coulda just painted the red one to be white eh?
Engine: 7.0L
sorry, yeah, it's been a busy month.
the red car had TONS of rust issues...thought you were aware of that.
billsfirebird
Jul 30, 2002 04:42 PM
