Replacing ball joints..
Car: '89 Flame red metallic GTA!!
..What does it involve? What special tools will I need if any? Thanks for any suggestions.
pretty straight forward job, your manual will have step by step and specs. you'll need a ball joint press, auto zone et.al. rents them, pickle fork, common hand tools. you might want to look at other parts you'll deal with along the way you might want to replace while you're there, like sway bar bushings, tie rod ends, etc.
Thanks for the info. One question though, what is the "etc." imply at the end of the last sentence. As in, what else is there to look at replacing there?
Thanks again
Thanks again
Car: 89 Formula 350 WS6
Engine: 383 miniram
Thanks again
Thanks again
control arm bushings
shocks
springs
insulators
pitman arm
tie rods
ball joints
swaybar bushings
wheel bearings
endlinks
did i miss anything?
I think that pretty much covers it cormyr, thanks. I will likely tackle some of those bushings, which brings up a question. I have installed bushings in Malibu GP cars before - not a a road car - however, we had to use a vice in order to force the bushings in. Am I looking at a similar scenario with the trans am as well?
thanks again for the input.
Engine: 383 miniram
yep, press in ball joints. i did all the bushings etc at the same time so i just took both control arms to my machinist and had him press everything in. saved alot of hassle.
Engine: 383 miniram
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Rag joint
Steering box
Center link
Idler arm
Tie rod adjusters
Strut mounts
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
don't bother with the pitman arm if your doing a front end rebuild, its a non wear item, do the idler arm forsure though
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
