Problem Spohn A arms
Old Aug 10, 2005 | 07:13 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I have just installed Spohn's A arm with spring box. I kept the original RS springs to keep ride height and a softer ride. Here's the problem the a arms dropped the nose about 3" now I scrape on all drive way aprons. At speed if I hit a dip in the road the bottom slams down on it leaving a shower of sparks. The wheels now hit the inner wheel wells on a turn. The car is pretty much useless this way! I sent Steve an angry E mail If I knew that it lowers the car I wouldn't have bought them. He answered quickly but was no real help. He claimed others have not had this problem. He suggested those poly spring top covers. Not a good idea it raises spring away from top pocket.
Here's the question.... Do I go for new springs ? And which ones ? Do I junk the $400 A arms? Does anybody make a rubber spacer to put between the coils? Any ideas?
Old Aug 10, 2005 | 10:12 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
i havn't had any trouble with mine, but then again i'm using coil overs so can't really relate.
Justin
Old Aug 11, 2005 | 12:05 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
gotta be something wrong with your springs or orientation or something.. it shouldnt drop 3"
try getting the moog ones they have at spohn in the pictures of the arms
Old Aug 11, 2005 | 12:15 AM
ss86's Avatar
Car: 78 Malibu
Engine: 357
The arms alone really shouldn't drop the car at all. They didn't drop mine at least.
Old Aug 13, 2005 | 03:46 PM
89rsragtop's Avatar
Car: blue
Ok I got those rubber spring helpers. They did the trick. Height is returned and the ride stayed smooth. This isn't a long term answer but will do nicely for now. Maybe new springs this winter When it comes off the road for the season.
Old Aug 27, 2005 | 10:36 PM
89rsragtop's Avatar
Car: blue
I have been thinking about my spring problem. Maybe the use of the spring compresser on the old springs did them in?
Old Aug 27, 2005 | 10:39 PM
89rsragtop's Avatar
Car: blue
another
Old Aug 28, 2005 | 06:07 AM
Dr G's Avatar
Those A-arms look great on your car! Unfortunately, I won't buy myself a set until Spohn eventually brings out a tubular K-member.
Are you sure the springs were indexed correctly when you had the stock A-arms? If I were you I would consider taking out the springs and measuring their length when they are not loaded and comparing it to the 'normal' stock length. Could they just be really old and sagging?
Old Aug 28, 2005 | 09:33 AM
89rsragtop's Avatar
Car: blue
They were and are now indexed correctly. When you see the design of the pocket it's more or less impossible to get them wrong. when indexed wrong the weight is on the tip of the spring making it too high. I would have done this to get the height but it will also cause the spring to fail.
This job was a real PIA and I'm not looking foward to taking it all apart again. When I do I will just replace them with new springs
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
