rear sway bar endlinks bent
Old Sep 20, 2005 | 09:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm guessing this is not a normal occurence, and this is a bad thing, (I can give a pic if it helps), but can anyone hazard a guess as to why this would happen, and how to prevent it?
Also, is there any logical reason why the previous owner would put in a nice new sway bar, nice new red poly swaybar-axle bushings, then put on the RHS a new poly endlink, and leave the stock rubber one on the left...? any guesses, aside from being a mickey mouse?
Old Sep 21, 2005 | 11:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
k, well either way, I had to cut them off to seperate them from the sway bar.... I'm repainting this goofy yellow sway bar to be black.... damn ***** previous owner...
anyway, does anyone know the P/N for the rear sway bar endlinks? I can't find them on energy suspensions webpage, only the front endlinks.... same part ?
I can't really measure mine, as they were bent, and now in pieces...
-J
Old Sep 21, 2005 | 11:47 AM
spcghst's Avatar
Car: 87 Camaro IROC-Z
Engine: 5.7TPI
Transmission: TH700R4
My front and rear sway bar endlinks are sheared off completely, so I can't really measure them. However, I have emailed Energy Suspension to see if they know and will post the reply here as soon as I get it.
Dave
87 IROC
Old Sep 21, 2005 | 01:08 PM
spcghst's Avatar
Engine: 5.7TPI
Reply from Energy Suspension:
I think we show the rear sway bar sets at the end of the Camaro listing. The bushings are only available with the complete rear kit. They are bushings only so if you are missing the hardware, you will have to buy good used or they may still be available through your local GM dealer.
I somehow get the impression that he misunderstood the question. However, after checking out summitracing.com we can buy a complete rear sway bar mounting kit that includes the endlinks and the bushings/brackets that go in the center.
HTH
Dave
87 IROC-Z
Old Sep 21, 2005 | 01:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
hmm, yea he musta misunderstood...
I found those, yea, 21mm rear sway bar... I'm not sure what I already have, but my frame bushings are fine....
I'll email them and check on just the endlinks, and sizing...If only summit had that mentioned...
Old Sep 21, 2005 | 02:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, got a response, he says they don't make endlink kits with hardware for my car...
I don't offer end link kits w/hardware the camaro/firebird. You will have to buy used or new from the Dealer.
so, if someone could be so kind as to tell me how long their endlinks are, i'd greatly appreciate it... (rears)
Old Sep 21, 2005 | 02:11 PM
spcghst's Avatar
Engine: 5.7TPI
This is almost funny. I was at my local Auto Zone this morning and they sell end link sets in various sizes by Energy Suspension. There was a sign by them that said to check the catalog for correct sizing, but the autozone didn't have a catalog handy, so I thought the website would have that info.
I might be able to take one of the sheared endlinks into the zone later this evening and see if I can try and come up with the correct size - or else I will have to order the summit kit.
BTW - I have the 24mm rear sway bar on my Iroc, so it might be different than what you need if yours is a smaller bar.
Dave
Old Sep 21, 2005 | 07:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
I should measure up my bar for comparison sake...
but I had a 2.25" long sleeve on mine, and energy suspension doesn't make that size... 2" or 2 3/8"
By the way it was bent, i'm guessing that was too long, so i'm going to try a 2" one. If anyone knows the "correct" length that I should have, speak up now...
Old Sep 23, 2005 | 06:48 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
http://www.p-s-t.com/gm/gmswaybu.html#links
performance suspension technology. i am using all their stuff and it works just as good as energy suspension. give them a call.
Old Sep 23, 2005 | 07:47 PM
spcghst's Avatar
Engine: 5.7TPI
Ok so I got kinda lucky. Thr front end links are the same on my 87 IROC as they are on a 79 Camaro which I just happened to have a spare set. Front end link problem solved. I then checked the rears against the fronts are they are the same! so if you can find the part # for the fronts you should have the same part # for the rears. Just make sure that the rear sway bar is parallel to the ground when installed and torqued to spec.
Dave
Old Sep 23, 2005 | 08:57 PM
87zjeff's Avatar
i would have to wonder if someone hasn't been into yours before. my fronts are longer than my rear ones. the stock ones were the same way.
Old Sep 29, 2005 | 12:12 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Autozone can look up the Energy Suspension part # in their computer if you ask them (or are in there enough like me and can run the computer by yourself...).
Old Mar 1, 2006 | 08:52 AM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
Transmission: 2.77 700R4 Auto
i bouth the slightly longer sway bar endlink from energy suspension and cut the spacing sleeve to the same as my old ones. There, you ahve a perfect fit.
Old Mar 1, 2006 | 07:44 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Unfortunately, you don't. The threads are made a certain length, and the nut stops turning at the proper preload on the bushings. Since you shortened the sleeve, the nut will stop before the proper preload is attained. Measure the length of your cut sleeve, and buy a new pair that same length.
Old Mar 1, 2006 | 08:29 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I bought the Energy Suspension link kits from Auto Zone.The kits are the same for the front and rear on my '83 Z28(this may or not be the case for other years).The kit is P/N 9.8117 "R" end letter = red bushings,"G" end letter = black bushings.But it's best to measure your exsisting bushings to make sure you get the correct kit(s).ES has a chart on the back on the link kits that gives the lengths of each of thier kits.
Auto Zone also carries the ES lube P/N 9.11110(P/N on the tubes of lube is 9.11108).Comes with 3 tubes.
One thing I found on the rear bar jack the car up and put her on jackstands.This is safer and it avoids preloading the sway bar itself if you try doing one side at a time.
Old Mar 2, 2006 | 10:50 AM
IrS89IROC's Avatar
Car: 89 IROC-Z
Engine: 355 L98
well it works just fine. i can tighten it more or loosen it more if i want i have so the bushings look like they're supposed to be.
Old Mar 2, 2006 | 07:08 PM
Lo-tec's Avatar
Works better than a broken endlink? Yes
Works correctly? No
You bolt them on, run the nut all the way down until it stops, and that is the correct preload. They are NON-ADJUSTABLE.
Old Mar 2, 2006 | 09:37 PM
Guest
Guest
Posts: n/a
All you need is a new bolt, thats no big deal.
Old Mar 2, 2006 | 09:49 PM
Lo-tec's Avatar
Is this a universal bolt, or dependant on the length of the sway bar endlink sleeve?
Enquiring minds want to know!
Old Mar 2, 2006 | 10:09 PM
Guest
Guest
Posts: n/a
The bolts included in most of those kits are just off the shelf bolts anyway (they are not shoulder or tapered seat bolts, only the factory ones are), grade 5 at that. They try to fool you with the cad plating, grade 5 are usually just zinc plated. I always replace them with grade 8, harder to bend and/or break. You can go to any hardware or decent auto parts store and find them. If you're worried about preload, tighten it up, measure the torque, and just set it to that torque reading with the new setup.
Old Mar 3, 2006 | 03:04 AM
83 Crossfire TA's Avatar
Why is this so dammed hard? They are shouldered to match the sleeve length and bushings, and usually grade 8 (grade 5 would only be good for about 15-20lb-ft and you'd probably snap them installing them)
If what you're getting is not then quit buying junk, even the ES, Prothane or Addco stuff is cheap, and the TRW or a good “HD replacement” would get you poly bushings and proper hardware for like $6…
Old Mar 3, 2006 | 09:51 AM
Sonix's Avatar
Car: 1982 Trans-Am
My ES poly endlinks (front and rear), had bolts with 3 lines on them, in my meagre experience that means it's a grade 5 bolt. I'm not terribly worried about them though.
Old Mar 3, 2006 | 10:19 AM
Guest
Guest
Posts: n/a
Exactly. Its an off the shelf, common, everyday hardware store variety grade 5 bolt, there's no shoulder its just like every other bolt that isnt threaded the whole way. Next time check the marks on the bolt that tell you what grade it is, they are really easy to read and understand.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
