need pics of lowered firebirds
Old Sep 23, 2005 | 10:19 PM
89_fireform's Avatar
Car: 89 WS6 formula firebird
Engine: 305 TPI :(
like it says, preferably drop zones, but doesnt matter im looking around
Old Sep 23, 2005 | 11:19 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
hotchkis 1 1/2" drop. car was sitting alittle high in the rear in this pic because it has High wall Drag radials on it
Old Sep 23, 2005 | 11:28 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Sportlines
Old Sep 24, 2005 | 06:28 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
sportlines, and 1 coil cut off the rear since i have a rear end with large axle tubes so it raised the rear .
Old Sep 24, 2005 | 12:14 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
drop zone springs 1.5" drop..
Old Sep 24, 2005 | 01:53 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
GroundControl weight jacks all around, probably a 2"-2.5" drop.
Old Sep 24, 2005 | 02:02 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
1bad406, do you have more pics? that car is beautiful, im doing the same hood and spoiler on my car, but staying red with snypers.
pics in the sig, eibach pro-kit
Old Sep 24, 2005 | 11:12 PM
Engine: 305 TPI :(
thanks guys keep em comin!
Old Sep 25, 2005 | 11:17 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Is that a company name or........what are weight jacks? Enlighten me.
Old Sep 26, 2005 | 12:14 AM
shr00m's Avatar
Yes, Ground Control is the company that sells weight jacks for our cars. Weight jacks are adjustable spring perches that let you use shorter springs and adjust the height at will.
Do a search, someone has posted a long thread with pics and info.
Kevin D.
Old Sep 27, 2005 | 10:30 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Got a few more pics for you...
Old Sep 29, 2005 | 08:41 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Sportlines,
Old Sep 29, 2005 | 01:23 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Sportlines
Old Feb 22, 2006 | 10:21 PM
Engine: 305 TPI :(
ttt
Old Feb 23, 2006 | 01:55 AM
Demon355's Avatar
I'll post mine up as soon as I get them installed.
1bad406, that color is amazing!
Old Feb 23, 2006 | 03:42 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Yet another sportline owner. I'd like to trim a little bit off or go weight jacks.
Old Feb 23, 2006 | 10:24 AM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i have 2" drop zones on my rs
Old Feb 23, 2006 | 10:30 AM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
k
Old Feb 23, 2006 | 11:31 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Here's mine with the pro kit and 245/50/16's
Old Feb 23, 2006 | 02:22 PM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Originally posted by Zepher
Sportlines,
Are these with 2" adapters? If so did you have to modify the wheel wells at all?and what are/were the offset on those wheels?
Old Feb 24, 2006 | 10:32 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Pro Kit
Old Feb 26, 2006 | 12:05 AM
Engine: 305 TPI :(
do any of you guys have problems with ground clearance? bottoming out and such?
Old Feb 26, 2006 | 02:43 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I bottomed out ALL the time when I had the retarded badly designed spohn t56 xmember. Since I swapped that xmember out for another one that tucks up farther I don't have too much of a problem.
Old Feb 26, 2006 | 03:13 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Hotchkis springs:
Old Feb 26, 2006 | 09:35 AM
shr00m's Avatar
No kidding! I cut that one edge flat instead of having it sloped down 2" more then needed. I haven't had a problem yet.
Kevin D.
Old Feb 28, 2006 | 10:13 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
as referred to 87 tpi heres the same car with some 17's with the pro-kit
Old Feb 28, 2006 | 10:15 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
and the same car with 18's
Attached Thumbnails need pics of lowered firebirds-47b6df03b3127cce975121f8047400000016108aamwzdk4btp.jpg
Old Feb 28, 2006 | 10:26 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
3 pix rule. My friends stock height 83 Trans am and his 87 formula with pro-kit, stock wheels, 4th gen rear
Old Feb 28, 2006 | 10:37 AM
Zepher's Avatar
those are with 2" spacers up front and an LS1 rear out back.
I had to bang in the rear inner fenderwells and run a 7/16" spacer when I ran the Vette 18" wheels since they were inset more. the front Vette wheels sat perfect.
The ZR1 wheels are inset just a hair and I had to clearance my tie rod ends slightly.
I have 2 sets of ZR1's, one set are the 36mm offset and the other set is the 56mm I believe.
Old Feb 28, 2006 | 09:32 PM
CheezX's Avatar
Sitting a little too high in the back. Need to cut another 1/2 coil.
Old Mar 1, 2006 | 06:05 PM
Engine: 305 TPI :(
cheez wat springs do you have?
Old Mar 1, 2006 | 06:37 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
hotchkiss - i'd love to drop it a little more, but with the long tubes, i'm not sure that's gonna happen...
i'm actually going to be measureing up the springs - i found out that they are just the stock heavyness - gona go stiffer all around for some better handling on the road course and autocross...
Old Mar 3, 2006 | 12:05 AM
Engine: 305 TPI :(
nice stuff guys
Old Mar 25, 2006 | 09:41 PM
Engine: 305 TPI :(
ttt
Old Mar 28, 2006 | 12:46 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Here is a link to pics of mine
http://www.team3rdgen.com/modules.ph...view_photo.php
http://www.team3rdgen.com/modules.ph...view_album.php
Old Mar 28, 2006 | 01:12 PM
Engine: 305 TPI :(
wat springs are those and wat drop
Old Mar 28, 2006 | 10:43 PM
CheezX's Avatar
Cut WS6 springs, handles much better than the stupid progressive drop springs I had. 1 coil taken off the front, 1.5 coils off the rear with spacer removed.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
