I bent A arm when putting in new Bushings
Old Sep 28, 2005 | 07:52 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I pressed in my Poly A arm bushings last night and bent one of the "ears". What can I do to fix this, or should I try to see if it works as is. Has anyone else done this?
Kevin
Old Sep 28, 2005 | 10:23 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
Yea; It happens almost every time. Most of the time you can beat it back into shape with a rubber or plastic mallet. Put a wood block under the other end to prevent any damage. Hope this works for you.
Old Sep 28, 2005 | 10:27 PM
shad's Avatar
Car: 1988 Iroc
Engine: 350 TPI 5.7L
Transmission: 700r-4
wow bent the a-arm? i did not know you could do that hehe, i replaced my bushings today and it went flawlessly, i dint use the a-arm as a pry, did you? the only thing that took me a long time was adjusting my sway bar to make it dead center. Umm but yea you can try beating the aarm back to shape and if that doesnt work, then just go as is, shouldnt be a big problem
1992rs/ss
Jan 31, 2025 05:10 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Cameeeero
Sep 18, 2015 04:00 PM
