tire size help?
Old Dec 1, 2005 | 05:57 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
tire size help?
Hi Guys,
We are going to put 18's on the roc but im not sure what size. I know i can go 275/40-45/17's on a 17" rim but what size 18" tire without rubbing? Dont really want that super skinny sidewall look either. What 's everybody running for size or suggestions on 18"s?
Do you thinK there is much of a difference between 17 and 18 in ride quality?
Dont want 20" either...
Thanks, Dora
Old Dec 1, 2005 | 06:07 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
It depends on what size your rim is. Is it 9.5" wide or what? IF you get 9.5 then i would get the 275 or 295. You will be fine just as long your backspacing is correct.
Old Dec 1, 2005 | 06:16 PM
Dora's Avatar
Car: 1986 iroc
Transmission: auto
dont know the width, suggestions?
Dora
Old Dec 1, 2005 | 06:19 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Old Dec 1, 2005 | 06:20 PM
on a 9.5" rim
Old Dec 1, 2005 | 07:08 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Moving to the correct forum. Please read the stickies. Thanks.
Old Dec 1, 2005 | 10:10 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'm going with 275/40-18's
http://www.miata.net/garage/tirecalc.html
Old Dec 2, 2005 | 09:34 AM
the 275/40/18 is probably gonna rub especially up front...with those specs, the tire will be 26.6" tall and lets say his car is lowered, he'll have a not so smooth ride.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
