i want a 315 mm wide tire in the rear...
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
yeah. 315 is def pushing it. If you do the math 315/35/17 wants to be on an 11" wide rim. I stuffed 335s on an 11" wide rim, just cuz i had the tires. I need to get some 315s. Just get what fits right. You will be happier in the end.
This all comes from experience. And believe me I am OBSESSED with w-i-d-e tires.
Car: 89 Formula
Engine: 305 is out and BBc is going in
Transmission: not sure
if i get a 11 inch wide rim what kind of back spacing do i need for it to fit in the rear and wht size spacers.and what tire do you recomend its a manual trans mission.with a 496 big block.around 500-600hp. And from time to time a 200shot.
Engine: LS3
tires depend on what you wanna do with the car. Drag, auto X, street. Any kind of wet driving? or even sorta coldish?
Go to tirerack.com they have some good reviews of tires and recomendations.
I just got some 4th gen offset rims and used 2" spacers.
(ZR-1s)
(ZR-1s)
Car: 89 Formula
the tires will be for drag racing at the track and then for cruising the tires are m/t street legal tires.also the zr1 rims are 11inches wide and a 2inch spacer and then im good it wont buldge out goofy looking?
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
