Boxed A-arms?
Old Dec 22, 2005 | 12:38 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Boxed A-arms?
I was talking to a friend of mine about redoing my front end suspension and steering. He told me he heard of people welding a sheet of metal to the underside of the A-arm to stiffen it. Sounds like a good idea.
Anyone have any experiences with doing this?
Old Dec 22, 2005 | 01:12 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
As long as the steel is heavy gauge then it should work. I did it with my panhard rod becuase I was bored.
Old Dec 22, 2005 | 01:41 PM
BarrisCustoms's Avatar
This is all you need for reinforcement.
Old Dec 22, 2005 | 02:12 PM
Car: 86 T/A
Engine: HSR 355
How long did it take to remove those, I'd love to do that.
Old Dec 23, 2005 | 02:01 PM
trumps2000's Avatar
Car: 1985 Z28
Thanks Barris, thats exactly what I'm looking to do. How thick are the plates? Steel I assume?
Thanks for the info.
Old Dec 23, 2005 | 02:11 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
It takes about an hour each side (less if you use a lift) to remove them. Jack it up, take the tire off, put the jack under the control arm, remove the upper strut nut, lover the strut down, keeing an eye on the spring. once the control arm is down far enough, the spring will "pop" out, you might want to stand back and use a long pry bar if the inboard side of the sping is hung up in the A arm. Next, pop off the lower ball joint, then the control arm bolts. That's all there is to it. I used some 3/8" scrap steel on mine, around the same places that are shown in the picture. Dont forget to paint over all bare metal, and use new poly busings in the control arm, as long as it's off.
Old Jan 1, 2006 | 09:47 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Any improvement that you can notice ?
Old Jan 2, 2006 | 12:03 PM
This is getting extreme. You will only notice such improvements if the rest of the car is built up to par. Otherwise, you will not notice any A-arm deflection if your strut mounts are rubber, your a-arm mounts are rubber, your chassis is flexing, etc, etc... when I say the car needs to be built, I mean built in order to feel any difference in this area of A-arm flex.
Old Jan 2, 2006 | 12:37 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
That's what I thought. Heck I didn't even feel much difference when installing the steering brace.
Oh well, considering I should change ball joints and stuff soon anyway, why not go to the junkyard, get used A arms, weld them up and then take them to a shop and have bushings pressed in.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
