How can I shift my rear axle over 1/2 inch to the left?
Old Jan 7, 2006 | 05:48 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
How do I shift my rear axle over 1/2 inch using my lakewood adjustable panhard bar?
My rear axle sits about 1/2 inch from center; over to the driver's side of the car. I have a Lakewood adjustable panhard bar.
What is the easiest way to reposition the axle over to the right about 1/2 inch? How much of the rear end do I need to disconect to make the adjustment?
Thanks for your advice.
Old Jan 7, 2006 | 05:50 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Put an adjustable panhard bar on it and adjust accordingly..
Old Jan 7, 2006 | 05:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jan 7, 2006 | 05:55 PM
Max's Avatar
Max
I have an adjustable panhard bar. I'm looking for some advice on the procedure. Of course I can turn the end of the bar to shorten it but what is the best way to shift the axle over? Do the LCAs need to be disconected, etc?
Old Jan 7, 2006 | 05:57 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I adjust mine on with everything hooked up. Just loosen the jam nuts, adjust until centered, the retiten and lock-tite the jam nuts.
Old Jan 7, 2006 | 05:58 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Shorten the bar 1/2" roughly. Nothing needs to be disconnected.
Old Jan 7, 2006 | 06:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
on a lakewood pandhard bar i believe he has to remove the drivers side bolt and turn the whole assembly by hand the desired amount then bolt it back up. I don't think it has two jam nuts and a center piece that can be spun with a wrench.
Old Jan 7, 2006 | 06:09 PM
Max's Avatar
Max
That's right. One end needs to be disconnected from either the axle or chassis.
So, I disconnect one end of the panhard bar and rotate that end to shorten the bar by about 1/2 inch and then reconnect it. Any tips on getting the bolt holes to line up again after I shorten the bar by 1/2 inch?
Thanks guys.
Old Jan 7, 2006 | 06:50 PM
Lo-tec's Avatar
Jack the rear and support it on the frame in front of the LCA's with the tires hanging. Shorten the bar, and push the rear over to align the hole. A screwdriver in the hole helps to align it once it gets close.
Old Jan 7, 2006 | 07:28 PM
Max's Avatar
Max
I'm thinking I might need someone's help. It's not going to be easy to shove the axle over and but the bolt back in place while I'm laying on my back under the car.
Maybee I could have someone sit next to the driver side rear tire and push in on it with their feet while I try to put the bolt back in place. Do you think this would be safe enough since the jackstands will be set up under the rear part of the frame?
Old Jan 7, 2006 | 07:44 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
I had to push on one of my wheels to align the bolt hole. As long as the weight of the car is on the jack stands and the car is supported securely and evenly you shoulda have to worry.
Just give the car a few good shoves before you crawl under there to make sure its secure.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
kyleb24
Aug 15, 2015 08:24 AM
