broken crossmember bolt
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
I'm sure many of you guys have had tranny crossmember bolts break off when taking out the crossmember. My question is, how have you repaired it?
In my application, the bolts are severely rusted and it seems that an easy-out is not an option. I already tried to drill through the bolt with little success. I drilled in maybe 1/4" and then numerous bits got extra dull and wouldn't cut anymore. Maybe my drill bits just suck?
I was thinking of drilling a few new holes in the subframes and using sheet metal screws.
Any suggestions?
Any suggestions?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sheet metal screws definately wouldn't hold it up. you need to get some real drill bits that are intended for drilling through hardened metal. Look in a grainger catalog, etc.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
After a heavy soaking of PB, mine came out with a left handed bit and a hi torque drill. All I hade to do was re-tap. Perhaps I got lucky...
cool.
thanks, those options beat the heck out of using a torch and f*cking everything up.
I've been around 2 cars that went on w/ life on 3 bolts. you have to remeber that your torque arm is pulling up on the trans...- not saying this is the best thing to do, but 4 bolts is kinda over-kill...
- I should also note that these cars had subframe connectors, which shouldn't really matter, but maybe w/ less twist...
Engine: 4++,350 & 305 CIs
also you have 2 remeber under braking the arm pushes down on the Xmember...
BTW I only have 3 bolts till i fix it but im going on 4 yrs now
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've drilled it out completely and dropped a bolt in though one of the access holes in the subframe. I used one of those long magnetic sticks and fed it though tell it fell in. Then wedged it in with something and put a nut on the bottom and tighted it up.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
