PA Racing Tubular K member question
Old Feb 3, 2006 | 12:42 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Anyone here use their stock A-arms with a PA racing tubular k member? Is this possible?
Old Feb 3, 2006 | 10:24 AM
92camaro's Avatar
PA should be able to make the K-member anyway you want it. Just call Jason an ask him.
Old Feb 3, 2006 | 10:21 PM
TA88GTA's Avatar
Thats right, and if they dont get it right the first time im sure jason wont mind attempting to get it right on the second or third try.
Old Feb 4, 2006 | 08:18 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i have a PA crossmember and i was told that the stock ones would fit, but they didnt. i ordered tubular A-arms front spohn and they fit fine.
Old Jan 15, 2008 | 07:08 AM
Artic-Trans am's Avatar
Car: 87 TA
Engine: 350 modifyed Stelth Ram
Transmission: 350 rew lock up
Axle/Gears: 9"
Re: PA Racing Tubular K member question
I have also the PA crossmember (K-member) but I think I have some clerance problems with the steering arms..
How did you do this fitment Heavy_duty29?
Old Jan 19, 2008 | 05:20 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
stock arms will not fit a PA unit.
Old Jan 20, 2008 | 01:53 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
yes, they will but you need to order the K member for stock a-arms. You will need to flip the center link to get the steering to work.
Old Jan 20, 2008 | 03:51 PM
Car: 87 TA
Axle/Gears: 9"
hi
That's true..
just flip the center link and then it's ok..
Attached Thumbnails PA Racing Tubular K member question-18012008011.jpg   PA Racing Tubular K member question-18012008013.jpg
Old Jan 20, 2008 | 06:08 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
that option wasnt available when i purchased mine.
matter of fact, he said all the bolts were included as well.
of course they werent. i call jason and he said the stock bolts work... which is again not true.
does flipping the centerlink have any affects on steering?
Old Jan 20, 2008 | 08:14 PM
nyytrousboy's Avatar
Car: 91 Mustang SS/O 10 tire car
Engine: 347 CI W/F3sc
Transmission: PG
Stock arms will work as long as you let me know you want to use them(we also build tubular ones for stock springs). As for the bolt they are not included nor have ever been but I do sell a bolt kit that is extra. Have more questions let me know.
Old Jan 20, 2008 | 09:29 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Flipping the center link doesn't effect the steering that I have noticed as long as you reset the toe. I have had nothing but great service from PA Racing. For street strip they have the best value out there. Plus shipping time is very quick.
Old Jan 22, 2008 | 08:48 AM
Car: 87 TA
Axle/Gears: 9"
Hi
I do not know the difference from a K-member used with rack and a K-member used with stock steering.
But mine PA K-member is not with any mounts for a rack and the previous ovner did use this one with no modification on the steering.
He had a Camaro.
I have a Firebird/Trans Am, and to do some mod's:
When I did try to mount the K-member it did interfere with my stock inner tie rod knuckle. My solution was to flilp the center link so the knuckle come forward from the center link.
If someone have other experience, then come with pictures!
I give you picture from my mounting (after I turn the center link), you might be able to see that if you turn the center link now it will interfere with steering.
PA have by the way not respond to my question I did send to them about this problem!
So to me they are not that good with service.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Aug 28, 2015 05:57 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
