South Side Machine Lift Bar Kit........
Old Feb 8, 2006 | 05:32 PM
jabird00's Avatar
Does anybody know who makes a kit like this, now that they were either bought out or went out of business? I have this setup on my 85' Firebird right now and love it. I am trying to locate this same setup for another project. Any information would be appreciated. In case your not familure with it, it does away with the torq arm and lower control arms. Almost like a ladderbar setup. Kit comes with frame ties, a rear crossmember, lift bars, and driveshaft safetyloop.
Old Feb 8, 2006 | 05:43 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
there was the same kit on ebay a couple of days ago dont know if is still on there or not as to who makes one im not sure if there is one out there someone else will come along that will know ill check ebay and see if is still on there it was around 100 plus 100 shipping
Old Feb 8, 2006 | 05:58 PM
91drag's Avatar
Engine: 350,289
the kit was still not on there this is all i could find i know its not what you where looking for dont know how good these are i thought about geting them but im broke http://cgi.ebay.com/ebaymotors/lift-...QQcmdZViewItem right now
Old Feb 8, 2006 | 06:03 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
jabird your kit does away with the control arms? i still have mine on there, am i not supposed to have them on there. i love my set up to.
Old Feb 8, 2006 | 07:26 PM
jabird00's Avatar
Thanks 91drag, I have been checking ebay to hoping to find another set.
Bluebeast, acording to the instructions you dont have to have them on there. The lift bars take the place of them (lower control arms) and the torqarm.
Old Feb 8, 2006 | 08:06 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
When I put my southside bars on I called southside thay told me to leave the lower control arm on run 50/50 rear shocks and 70/30 front struts.
Old Feb 8, 2006 | 08:16 PM
jabird00's Avatar
Once the lift bars are welded to the rear axle, theres really no scence to keep the lower control arms. The bars have no affect. Mine are off and leaves straight. Check out my post on Pontiac engine swap, jabird00's Firebird with pics. You can see the lift bars in action.
Old Feb 8, 2006 | 08:30 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Looks good and I like the pontiac motor. Maby thay work just the same with or with out the lower controll arms on. I can tell you when I bought mine I remember calling them and asking about the lower controll arms and they said to leave them and gave me the shock rates .they look useless under the car. but best 60 ft with a 28/10.5 slick was 1.40
Old Feb 9, 2006 | 06:14 AM
bad90rs's Avatar
Car: 1990 rs
Engine: 350HO
Transmission: 350th soon
Axle/Gears: 323
Your in luck JaBird00.I have this kit and never installed it.I got it from jegs years ago.There are couple of parts missing,,,frame ties,driveshaft loop,and metal straps that weld to lift bars.I only have the crossmember and lift bars. $100 plus shipping and ther yours. call 215-450-5622 for questions. I live near phila.
Old Feb 9, 2006 | 05:07 PM
jabird00's Avatar
ross, same here 1.39-1.40 best for me was 1.37 60 ft., thats with 29.5 10.5's . The picture with the burnout was before I minitubbed it. The one with me leaving is the now minitubbed, shortened the 9" to make it look better.
bad90rs, I dont think I can use those without the frame ties? Im not sure if anybody makes them like the ones you need for the lift bars? The rear crossmember is to be welded to the fram ties that come with the kit. But then again im not sure how other frame ties connect.
Old Feb 9, 2006 | 05:56 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
jabird i jsut checked out the pic in the other forum. that thing is bad ***!!!! very nice!!!!!!!
bad90rs's Avatar
Car: 1990 rs
Engine: 350HO
Axle/Gears: 323
thats cool. I'll keep them if anybody needs them.Oh by the way how good is that b&m change over kit for 350 trans in a f-body if anyones used it before.i dont have the money to buy sphon's kit.
Old Feb 9, 2006 | 06:00 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
i had the change over kit i personally didnt like it. i have the spohn kit now much better. but atleast that kit will get you rolling if need be, but save for that spohn kit
Old Feb 9, 2006 | 06:04 PM
bad90rs's Avatar
Car: 1990 rs
Engine: 350HO
Axle/Gears: 323
I know, thats a bad a** kit.Maybe late summer i'll get it.
Old Feb 9, 2006 | 06:55 PM
jabird00's Avatar
I dont have that changeover kit you are talking about. I have a Turbo 400 Trans. and had to make my own transmission crossmember. I had to fab up alot of things to get my car the way it is today. I even made my own engine and frame mounts, that was bofore Indian Adventures started making them.
Thanks for the compliment Bluebeast.
Old Feb 9, 2006 | 06:58 PM
jabird00's Avatar
Oooh, I forgot to mention. I use to have a turbo 350, Blew apart 3 of them. Then I went to the 400. Problem solved. I guess to much HP and Torqe.
Old Feb 9, 2006 | 07:15 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Jabird forgot to mention bitching car!! Always like the pontiac and olds combos. Had a friend years ago had Lemans with a 455 that he told everyone it was a 400 with stock intake and ex manifolds the car went bottom 12s on protrack tiresand boy could it 60 foot. Made some good money with that car.
Old Feb 9, 2006 | 08:01 PM
jabird00's Avatar
Sounds good ross. I have always been a Pontiac Man myself. My last car was a 70' TA with 455 HO in it. I wish I still had that car.
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
Dialed_In
Aug 20, 2015 01:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
