column and shaft
column and shaft
anyone make a billet piece for our cars that will bolt up directly?
really looking to clean up the steering piece and brake section with something billet or close to it.
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
flaming River i believe makes something like this, i dont believe its a direct replacement though . You may have to modify something. There was a tech article in one of the Chevy High Performance Mags last year on it when they put a detroit speed steering box in a thirdgen.............jt
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
The picture above is adjustable, there are differnt types. Just need to check out flamingriver.com. I had it figured out once but cant find my notes. It was in the $250-$280 range
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I was looking into the Borgeson joints. I want SS everything in my car and IIRC Flaming River didnt have much of a selection but it has been a while.
http://www.borgeson.com/products.htm
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Borgeson also has aluminum u-joints and shafts that you can polish up.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Too much bling for my taste. I've got a modified one from an Astro Van because it uses u-joints instead of the normal type couplers.
I needed it because the factory steering shaft had to be relocated to get past the headers.
I needed it because the factory steering shaft had to be relocated to get past the headers. Member
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I've think read about the astro van mod but I couldn't find the post. Doesn't it eliminate the rag joint. Where did you cut the astrovan shaft, how many inches above and below the u-joint?
Ben
Ben
Car: 87 IROC L98
I cut the u-joint yokes out of the astro van shaft and inserted the third gen shaft into the yokes. I then welded the u-joint yokes to the shafts. The shafts are the same size diameters. It's just that the Astro van uses u-joints and the third gen uses a rag joint at the bottom and a coupler at the top.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
