What's the weight of subframe connectors ?
Old Feb 10, 2006 | 09:36 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I found some heavy steel tubing today, however I'm concerned that the tubing may be too thick, too heavy. for SFC's. And no, can't measure the thickness right now, not until I cut the welded on caps off.
Old Feb 10, 2006 | 11:37 PM
Thunderfest's Avatar
About 40lbs
Old Feb 10, 2006 | 11:49 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
That's just for "straight" ones, right, not including the additional brace that some use, or the design the KB are ?
Dang it, I bet the tubing I got is more like 40 lbs each *lol* gotta weight it
Old Feb 10, 2006 | 11:56 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Just weighed one tube. Looks like it may be 5 feet long, and it weighs 18 lbs. It may be a bit too heavy, but I may just go with it, heck I'd have some real stiff SFC's
Old Feb 11, 2006 | 04:21 AM
Night rider327's Avatar
Car: 1988 Camaro
I have Spohn round tube SFC. 4 bars. Two main ones and the 2 little "Y" bars.
All 4 bars are 25 lbs
Old Feb 11, 2006 | 08:33 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
But those are not as thick, i.e. not as big nor massive as some other SFC's, correct ?
Old Feb 11, 2006 | 03:15 PM
Car: 1988 Camaro
Well thats the odd part. You would think the Spohns would be much lighter than others based on thier looks.
I don't have other third gen SFC but the SSM 2"x3" rectangle type SFC for my second gen only weighs 30 lbs for the set.
25 for the little round spohns and 30 for these and they are longer, wider, taller, etc
Old Feb 11, 2006 | 03:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
my jegs subframes were 46 pounds shipped to me.
Old Feb 11, 2006 | 03:26 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK, not sure how much mine will end up weighing, but my guess would be anywhere between 35 and 50 lbs, oh well it'll work.
Thanks guys
Old Feb 12, 2006 | 06:59 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
umi subframe connectors are 44 pounds and the difference it made in my car is unbelievealbe. so glad I got in on that group purchace
Old Feb 17, 2006 | 10:21 PM
UMI Performance's Avatar
Actually the SFC's packed for shipping weigh 44lbs...the actual weight of the set is 34lbs, thank you though
Ryan
Nervous2
Oct 8, 2015 10:53 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
