18 X 9'' Rim up Front??
Old Mar 20, 2006 | 08:21 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Will an 18'' X 9'' rim fit ok up front with some 265/40's??. I am ordering rims tomm. and I am trying to make sure I make no mistakes!
Old Mar 20, 2006 | 10:30 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
From what I understand, it would be possible, but with that big of a wheel you will most likely run into rubbing problems when your wheel approaches full lock (if not earlier). I would suggest not running wider than 8inches wide up front. In the back, 9/9.5 would be perfect
Old Mar 20, 2006 | 01:39 PM
Car: 91Z
I have fit a 17 X 9 with a 275/40/17 on the front with no rubbing, but I am worried the 18'' rim will just be too big in 9'' wide. I think I am just going to go 8'' wide and forget about it.
Old Mar 20, 2006 | 06:45 PM
CrazyHawaiian's Avatar
Car: too many ...
As long as you use the same backspacing/offset specs you did with the 17x9 wheel AND the overall tire height of the new setup is the same as the old setup with 17x9 ... then it'll fit no problem.
Old Mar 20, 2006 | 09:34 PM
89ta383sc's Avatar
Car: 89 ws6 trans am
Engine: 383 supercharged
Transmission: t-56
Axle/Gears: 9 inch 3.90's spooled
I have seen and heard of people running 18x9.5 in the front and the rear. i have also seen 18x10.5 in the rear. so I now they will fit. I just dodn't kjnow about that tire size. you can get away with a 255/35/18 for sure.
Old Mar 20, 2006 | 10:34 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I ran a 265/35/18 in the front of my Iroc with no rubbing at all but I was stock height. I sold the rims to 87tpi for his T/A and it was lowered(prokit) and he said if the tires where new they would rub.
Old Mar 21, 2006 | 07:58 AM
Car: 91Z
Thanks, this is the type of post I was looking for!! Does he meen they would rub when the wheel was turned, or they would even rub going straight??(like over bumps and stuff)
Old Mar 22, 2006 | 01:28 AM
kairles's Avatar
Engine: 383/LGX
when turning. now hes running 255/35's I think
Old Dec 9, 2006 | 09:01 PM
BOTTLEDZ28's Avatar
Transmission: A4
91wtROH17's, how did yo umakeout with your wheels? Did you end upgetting 18x9 wheels up front? Im debating weather or not I will do the same. What BS did you go with?
Old Dec 11, 2006 | 07:32 AM
Car: 91Z
Hey BOTTLED, I did go with 18X9 up front and I used 275's, they rub very little at full lock. I say go for it and don't worry at all. As far as the tire size, I am running Falken's up front and they seem to be a little more narrow compaired to say a BF or Goodyear tire. Good luck.
Old Dec 11, 2006 | 09:45 AM
BOTTLEDZ28's Avatar
Transmission: A4
what backspacing did you end up going with. Im thinking I should try 5 3/4". Then once I add the C5 brakes, they will push the wheel out another 1/4".
Old Dec 11, 2006 | 09:53 AM
Car: 91Z
Umm, i don't know what the backspacing is because when you order the ROH wheels they already have them premade to fit the application. I can tell you that whatever backspacing they use on the 9'' rim is PERFECT for the front, so mabey call JD wheels or group 1 and ask what the backspacing is that they use on a RT 9'' wide wheel for a third gen. Once you get that you can obviously just subtract whatever the C5 brakes add and you will have the right backspacing, sorry I don't have the #'s for you though.
Old Dec 12, 2006 | 07:27 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
some questions for you. what sizes, 275/??/18 front and what rear? do you use spacers? im thinking of upgrading to 18" drift-rs for street duty
Old Dec 14, 2006 | 07:54 AM
Car: 91Z
I am running 275/35/18 front and 295/35/18 rear. No spacers required.
Old Dec 18, 2006 | 12:39 AM
Kandied91z's Avatar
i ran 275/35/18 on a 9.5" in the front... couldn't stand it. the extra width was pointless on the street and it wore out my steering that much faster. but it fits and i was running baer brakes which push out 1/4" more as well as a coilover conversion.
Old Dec 18, 2006 | 07:45 AM
Car: 91Z
To be honest I have no idea how you could not stand it, unless that 1/2'' made all of the diff.?? I have really no problems with this set-up and the thing BARELY rubs at all!!
Old Dec 18, 2006 | 07:48 AM
BOTTLEDZ28's Avatar
Transmission: A4
I just got an email from newstalgiawheel.com and they said that their Boyds JYD wheel in an 18x9 size will have a 13mm offset with a desried 5.5"BS. Just posting this in case anyone esle wanted to know. I think this should work out fine for the front. the back wheel in 18x10 with a 6"BS will also have a 13mm offset
Old Dec 18, 2006 | 07:51 AM
Car: 91Z
Sounds good to me, I think your car will look great with those wheels. When I have a little extra paper to through around I will get some better wheels!
Old Dec 18, 2006 | 07:58 AM
BOTTLEDZ28's Avatar
Transmission: A4
well I hope it looks good with those wheels. theres a lot of other wheels out there that Id like to have but there just as bit too much money and I dont exactly live the safest neighborhood. My plan is to have some vinyl stickers made that will go over the spokes of the wheels so I can see what they will look like blacked out in the center. If it dont look good on my car then I will just remove the decals. The pic of my car in the sig is nothing like what my car will look like in the spring. I now have an SS hood, and soon the windows will be black as well as the headlight pockets and the center scoop on the hood. Should look alot better then what it does now.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
