wheel experts!!-> 255/40/18 on 18x9 wheels?
Old May 29, 2006 | 05:07 PM
UDAMON's Avatar
Car: Mazda Protege5
is this ok for all 4 wheels without risking rubbing? im at stock height right now but do plan on lowering it in the future. any help is appreciated thanks!
Old May 29, 2006 | 06:14 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
it all depends on the offset of the wheel...youd have to tell me exact dimensions for me to be able to give you a definate response...
the wheels is 18X9 with what offset? then ill be able to tell you if youll rub...also the 255 will work fine with that size you could go a little bigger if youd like...up to a 275 if you wanted
Old May 30, 2006 | 09:51 AM
UDAMON's Avatar
Car: Mazda Protege5
my bad.
from the site:
The wheels are 18x9 with a 7.00" backspace (+50mm offset). The lug pattern is 5x4.75 (120.65mm).
i was planning on 2" spacers
thanks for the help God Speed!
Old May 30, 2006 | 10:21 AM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
I just put 275/35/18 on a 18x9.5" wheel all around and I'm having zero rubbing issues. My wheels are +38mm so I used a 1.25" adapter.
pic here http://onclickpix.com/34490.jpg
Old May 30, 2006 | 03:37 PM
UDAMON's Avatar
Car: Mazda Protege5
ah yes looks great. do you think that your size tire would look goofy on a 9 in wide rim?
Old May 30, 2006 | 09:47 PM
Car: 1989 GTA
ok man here is what you need to know
with a 50 mm offset...thats WAY too much backspacing...a good stock backspacing is 4.63" you can go about an inch deeper without problems in the rear...in the front the stock backspacing is 4" even
SOOO...here is how we fig out what you need...you will need adapters...check out adaptitusa.com
1" = 25.4mm
9/2 = 4.5" + a 50MM offset (50mm = 1.96") = 6.46" of backspacing for the front...you def have to push that back out...so add a 2.3" thick ADAPTER (SPACERS ARE UNSAFE) and now your backspcing is 4.16" and youre at nearly stock backspacing and NO RUBBING and barely any excess frontspacing
NOW for the rear you can prob tuck those a little more if youd like
once again 9/2 = 4.5" + 1.96" = 6.46" of backspacing
stock = 4.63" of backspacing with about an 1"-1.5" of extra clearance
6.46 - 1" thick adapter = 5.46" of backspacing which should tuck nicely and not rub
overall
youd need to get adapters 5X4.75 to 5X4.75
2X 2.3" thick for the front
2X 1" thick for the rears
once again the reason for such thickness on the fronts is bc the fronts are used to having NO offset on a 8" wide rim so with 50mm of offset on a 9" wide rim youre gonna have to compensate and space the rim back out to reduce that backspacing
Old May 30, 2006 | 09:51 PM
Car: 1989 GTA
if i were you id do
245 40 18s on the front
275 35 18s on the rear
it will look really nice, give you nice amount of rubber and wont rub
Last edited by GodSpeedGTA; May 31, 2006 at 12:08 AM. Reason: Automerged Doublepost
Old May 30, 2006 | 11:24 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I would go with a 265/35-18 on that 18x9 and maybe a 275/35-18 on the rear wheels.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
rudolphschenker
Sep 4, 2015 02:41 AM
