What size spacers would I need with these wheels?
Old May 30, 2006 | 12:24 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Corvette C5 Y2k wheels, 18x9.5 front, 18x10.5 rear? Or is it even possible? Thanks ahead of time!
Old May 30, 2006 | 07:25 PM
'Shifter's Avatar
Car: 87 Z-28
BTT
Old May 31, 2006 | 12:03 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
you will need 2" spacers front and back, i have those wheels also
Old May 31, 2006 | 01:43 PM
'Shifter's Avatar
Car: 87 Z-28
Did you have to hammer your wheelwell or trim fender lips? Do they rub at all?
Old Jun 1, 2006 | 01:10 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
nope, not at all, it fits really nicely and i even have it dropped 1.5", i will post a pic in a day or two, i am finishing up putting corvette brakes on the front, so it might change things, but i believe it might bring them about 1/4" which would be great. so i will post a pic of the wheel with the new brakes. but i just relized that my fronts are only 17" 245/35/17's, so your fronts might be different then mine. my rear is 275/40/18 and they fit awsome.
Old Jun 1, 2006 | 02:16 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
according to skulte it looks like I'm guessing 2" up front depending on the backspacing. And 2.25" in the rear. Billet Wheel Adapter FAQ - Skulte Performance Designs
Old Jun 1, 2006 | 09:39 AM
'Shifter's Avatar
Car: 87 Z-28
Excellent! Can't wait for pics! Thanks very much guys!
Old Jun 4, 2006 | 10:12 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i dont have spacers in the rear because i have 4th gen axle which are about 4" wider then 3rd gens
Attached Thumbnails What size spacers would I need with these wheels?-dscf0055.jpg   What size spacers would I need with these wheels?-dscf0058.jpg
Old Jun 5, 2006 | 04:15 AM
Ltrain925's Avatar
Car: 85 T/A
Engine: l98 ,cam,exhaust
Transmission: beefed up 700R4
Axle/Gears: 2000 ss 3.42s
i'll get pics as soon as i can probaly tomarrow but i have 4thgen rearend with 18x9.5 in rear, and 17x8.5 245/45/17 in front i used 2inch spacers in the front and they still actually rup on the fender but i can't even notice it, it only does it if you turn the wheel like doing a U turn. 9.5 in the front i don't think a 2.25 spacer would even do it but they may. the 8.5 rims with low profile tires just keep the tire and rim even with the fender. i think a 9.5 would definitly stick out maby a little to much and look ghetto, but not sure take the wheel off and measure it thats what i did then you'll see how it will look.
Old Jun 5, 2006 | 11:05 PM
Ltrain925's Avatar
Car: 85 T/A
here are the pics of my car once again front 17x8.5 245/45/17 rear 18x9.5 275/40/18 the rear is a 4th gen rearend,front required 2"spacers the front tires look to be weird shaped kinda inward because i am almost done with putting my new engine in and i haven't put any force on the springs yet so thats why it looks all jacked up but i can tell you they don't stick out at all and tuck very nice under the car. and the other post is the other 2 pics couldn't post them all togeather
Attached Thumbnails What size spacers would I need with these wheels?-dscn0424.jpg   What size spacers would I need with these wheels?-dscn0425.jpg   What size spacers would I need with these wheels?-dscn0426.jpg
Old Jun 5, 2006 | 11:07 PM
Ltrain925's Avatar
Car: 85 T/A
other 2, last pic is of the rear if you want a pic of the front rims with a clear pic of the spacers just pm me i will send you one.
Attached Thumbnails What size spacers would I need with these wheels?-dscn0427.jpg   What size spacers would I need with these wheels?-dscn0428.jpg
Old Jul 2, 2006 | 01:23 PM
superNOScamaro's Avatar
Car: 91 CAMARO RS VERT
Transmission: t-5
Axle/Gears: 10 bolt/3.08
so are your rear wheels 10.5 wide correct? and you have a 2" spacer? i'm just making sure because i really want these wheels to fit my car the first time i put them on.
Old Jul 2, 2006 | 10:28 PM
CrazyHawaiian's Avatar
Car: too many ...
Keep reading ....
Old Jul 3, 2006 | 11:47 AM
Transmission: t-5
does anybody have a good picture of the rear with c5 zo6 wheels 18X10.5 without the 4th gen rear? if so what size of spacer do you have?
Old Jul 5, 2006 | 12:10 AM
BackInBlackGTA's Avatar
Car: 1989 Trans Am GTA
Engine: MiniRammed 11.5:1 383
Transmission: 700R4 w/ 3400 stall
Axle/Gears: 9" Ford/3.70:1
TTT
I am wondering the same thing as I'm thinking of getting 18x9.5 and 18x10.5 Z06 rims...I have a 9" Ford rear but it is the stock third gen width
Old Jul 5, 2006 | 01:10 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
you going to need 2 inch spacers in the back just like the fronts, 4th gen axle is 4" wider, dont know about 9 ford end
Amillionoh7
May 24, 2020 08:01 AM
toronto formula
Nov 10, 2015 06:17 AM
kah992
Aug 19, 2015 02:55 PM
knight72
Aug 10, 2015 09:32 PM
