delalum vs urethane
Old Jun 30, 2006 | 06:21 PM
laiky's Avatar
delalum vs urethane
As mentioned in my other post, i'm rebuilding a set of control arms. i was thinking about delalum bushings to replace the polygraphite i now have. What is everyones experience/opinion of delalum? is it that much better than urethane?
Old Jun 30, 2006 | 10:18 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Buy them. They work well.
Old Jun 30, 2006 | 11:22 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Originally Posted by DRR
They eventually do wear and get slop, but that takes about 100,000 miles of normal street driving.
I wore out the insert in one of my global west rear LCA's in less than 10k miles. The plus side is it cost more for shipping than the new insert ($3)!! The down side is the other end had a spherical bearing, which I also wore out and cost $60 for a replacement. I don't think it's worth it for the front A-arms.
Old Jul 1, 2006 | 10:09 AM
laiky's Avatar
if the existing urethane is good, then i'll just swap them over. I guess what i'm asking is if the delalum is dramatically better than urethane. 0 dollars vs 120 dollars. What is everyones opinion? Will i see a 120 dollar difference?
Old Jul 1, 2006 | 10:36 AM
Lo-tec's Avatar
I don't think so...I would put your $120 to use elsewhere (maybe a strut tower brace...you'll feel a difference with that).
Old Jul 3, 2006 | 01:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
www.mcmastercarr.com
p/n #8576K25
not sure if that's the right diameter, but it's 1.5", $9/ft. Lop that into 2" long chunks, or whatever size you need, center drill the bolt hole. I'm seeing $9 to make a set for what you want. Assuming this delrin would work.
Nice to know del-a-lum = delrin. I was always curious what del-a-lum was....
Old Jul 3, 2006 | 07:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The single one issue with Del-a-Lum bushings: are the lower A-arm pivot points in direct alignment with each other? If not, those bushings will wear out in no time.
And, there is no guarantee that they are in alignment. Nature of the beast (or design).
I'll never use them in this application.
Which is why spherical bearings are used for lower A-arm pivots.
RBob.
Del-a-Lum stands for 'delrin on aluminum'. In the correct application it works OK.
RBob.
Old Jul 3, 2006 | 10:59 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
RBob.
Correctl It is a machined billet aluminum core with a machined sleeve of Delrin over it. I've run them for about 8 years now without any problems.
Lon
Old Jul 4, 2006 | 12:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
lonsal, in what application? in a-arms, or other?
what would be the "correct" application for del-a-lum bushings Rbob? LCA's? panhard?
nifty, AL, and a delrin sleeve... hmm, something I could make at home.. How thick is the delrin? half and half AL/Delrin, or more swayed to the delrin?
Old Jul 4, 2006 | 01:10 AM
lonsal's Avatar
Front a-arms is where I used them. I don't recall the exact thickness of the Delrin, but it was a thin diameter. Looking at the picture on GW's site has refreshed my memory of the construction. Check it out:
The advantage of them vs. polyurethane or OEM rubber is the lack of stiction.
Lon
Old Jul 4, 2006 | 11:21 AM
Julie Bergman's Avatar
Car: 91 Formula WS6
Transmission: five speed
Lon
Hey Lon! Also ran this set-up on '84 CMC third gen, no problems in five reliable years. Is it in my new '91 Formula street car project? - you bet!
Old Jul 10, 2006 | 04:10 AM
83 Crossfire TA's Avatar
This kind of machined support sleeve with a durlin or nylon liner is actually a very common industrial bushing assembly, global west just decided to give it a fancy name. Also, the ones that you’ll usually find in an industrial application will have the shoulder (the part that’s washer shaped in the GW part) as part of the liner, and then the whole deal will be fluted to channel grease from the zerk in the support piece through the whole assembly. My dad used to have a whole stack of them sitting in a cookie tin that he got as engineering samples for some equipment he was designing.
I’m not sure that there is a real advantage in them, and if you wanted to run something that doesn’t deflect you could get solid, circle track style bushings for the control arms for a fraction of what these things cost.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Catcher55
Aug 15, 2015 07:08 PM
TBIWorks
Dec 4, 2001 01:35 PM
TBIWorks
Nov 29, 2001 01:03 AM
