front sway BAH
Old Jul 4, 2006 | 12:00 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
front sway BAH
what a total PITA
all i was doing is try installing the wonder bar,
i couldnt seem to install it right, so i tried to just put it back in
without the braces between.
even then the freaking bolt doesnt go into the hole..
I might have stripped it?
im not sure what it is but the bolt just doesnt engage the hole right,
like i know the bolt and hole is aligned but it still wouldnt screw in.. WTF?
is that a bad thread or do i need to just engage the hole perfectly or something?
caz i think once the bolt is in, its a snap. but bolt is having such hard time getting the first screw(like it doesnt start to go in)
any feedback is appreciated.
Old Jul 4, 2006 | 01:08 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
When I installed my wonder bar, I had a time trying to get one or two of the bolts in right. What I did was took a break and drank a soda and sat down for a few min. After that it took me just a few min to get them on. What I did was loosened the other bolts almost all the way so I could move the assembly around a bit. After I got all four bolts started, I tightned them down and done.
Kris
Old Jul 4, 2006 | 02:01 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
My wonderbar went in very easily. Did you order the longer bolts from TDS to make up for the wonderbar? My old bolts were rough and had trouble going back in, but the new bolts went in nicely.
Old Jul 4, 2006 | 07:20 PM
sogabe's Avatar
Engine: 3.1L
thats what i was thinking..
since this had to be done without jacking up the car,
i have no much room
and it was such a PITA to hold the bar up while trying to align to holes.
i jacked up the swaybars but still the bolt have very hard time reaching the hole.. so i thought of longer bolt too.
i didnt know TDS sells one, i think im gonna order one then.
hey thanku!
Old Jul 4, 2006 | 11:57 PM
krisb410's Avatar
I used the stock bolts. Just to let you know
Old Jul 4, 2006 | 11:58 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Axle/Gears: 3.08
I put two bolts in the far bolt holes, (the extra 3rd hole on the wonderbar) to hold it up, then put in the actual bolts with the sway bar bushings.
I couldnt imagine doing it easily without a jack....It will make it much easier for you.
Make sure you order 6 new longer bolts.
Top-DownSolutions.com
I got all 6 just to be sure I had all new bolts and to make sure it went in easy.
Old Jul 5, 2006 | 12:09 AM
krisb410's Avatar
What a waste, i just unbolted the sway bar, put the wonder bar inbetween, and started tighntning the bolts. I didn't need a jack to hold up anything. I just got frustrated for a bit and took a break. you guys are making this alot harder than it is. I did this with jack stands holding up the car, and me on my back.
Old Jul 5, 2006 | 12:17 AM
sogabe's Avatar
Engine: 3.1L
instruction says u need this job done while the suspension is fully loaded,
so thats why i didnt jack it up and do it.
did u jack it up from the control arm or something? just wondering..
Old Jul 5, 2006 | 12:25 AM
krisb410's Avatar
I had my jack stands under the A arms
Old Jul 5, 2006 | 01:31 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
ha i just slid on my back and did it but my car also sits higher than my bros Furd ranger. LOL! i really need new springs.
Old Jul 5, 2006 | 02:00 AM
CrazyHawaiian's Avatar
Car: too many ...
I agree this thread is making it seem harder than it really is. I share in your frustration, when installing a Global West wonderbar on my IROC-Z, I also got kinda pissed off about how simple it should be compared to how hard it actually was. But it wasnt that bad! I did mine with my car in the air, suspension unloaded. Re-used the stock bolts after cleaning them with a wire brush. When you torque everything to spec, then the suspension should be loaded. But while just threading the bolts in, dosnt matter. I did mine by myself laying on my back, both hands holding one side of the swaybar and wonderbar, foot supporting the other side of both. Thread in the first sides bolts, then switch it around and get the other side going. Then when they're all threaded, set up the endlinks but do not tighten, put the car back down to load the suspension, then tighten everything down to spec (helps to turn wheels to full lock when tightening endlinks w/ car on the ground).
Old Jul 5, 2006 | 10:56 AM
sogabe's Avatar
Engine: 3.1L
yeah maybe i did make it sound harder..
i was just frustrated caz i tried it with no jack,
so i was working in such a small space and the braces kept falling on me
thanks for info though guys..
just for convinience i decided to buy the longer bolt, thanks!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
