sway bars
Old Jul 10, 2006 | 09:45 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
sway bars
ok well how big of a difference will i get from a front 32mm sway bar compared to the stocker on my 89 base firebird 5.0tbi? also whats the difference between the 32 and 36?
Old Jul 11, 2006 | 07:40 AM
Mr. TurboTA's Avatar
I noticed a big difference by changing out the regular sway bars on our '91 Firebird with the Sport Appearance package, to the 36/24 setup from a Trans Am, along with putting on new Energy Suspensions Polyurathane bushings and endlinks, as well as a wonderbar from a IROC.
The car now takes turns at speed alot better, and higher speeds!
Go for the top of the food chain, and run wild!
George
Old Jul 11, 2006 | 08:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jul 11, 2006 | 01:06 PM
Engine: LO3
well whats the size i have now? the one i can get is a 32mm or is that what i have already?
Old Jul 11, 2006 | 06:58 PM
Either way, I would go the biggest one you can, a 36mm front.
Even with just this bar and your stock rear bar, your car will handle way better! You will be able to take tuns at higher speeds.
Both 36mm front, and 24mm rear, and with a wonderbar, go for around a hundred or so on this site, used, less if you find them at a yard and pull them yourself.
A harsher ride, yes, but you will love thew way the car handles!
Heck, just adding wider tires will feel better too!
We went from 15s to 16s, Diamond Spokes with 245/50 tires on our Bird, and we won't go back.
If we ever get another Bird, we will do the same thing again!
Good luck,
George
Old Jul 11, 2006 | 11:50 PM
Engine: LO3
yea i already did the wider tires i got IROC 16" rims rather than my stock 15" pinwheels.
still looking for the answer on my stock sway bar size
Old Jul 12, 2006 | 07:46 AM
As for your sway bar size,
If they have a tool store around you, check them out.
I picked up a caliper for measuring thickness of bars and such, for only 99 cents!
It was made out of plastic, but works great!
I have them in my tool box, and check sway bars at the yards.
I would guess that you would have either a 30mm or 32mm bar stock on your car.
Sorry I can't help you out any more.
George
Old Jul 12, 2006 | 10:21 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
If your car was a TA you proably have 32mm front and 19mm rear. If your car was a V6 car they may even be smaller.
Old Jul 12, 2006 | 02:25 PM
Engine: LO3
ok so im prob 30mm because i am not a v6 and i am not a trans am i have a 305tbi
Old Jul 12, 2006 | 06:22 PM
Randy92Z's Avatar
Engine: Miniram 383
Im not sure if Pontiac did it the same as Chevy with Camaro, but if You got a V8 car w/factory 16 inch wheels, you should have gotten the 32mm front and 19mm rear bars. Hope that dosent confuse you.
But if you car came from the factory w/15 inch wheels, then you might have the 30mm front bar.
Old Jul 12, 2006 | 09:23 PM
Engine: LO3
bah i prob do have the 30mm o well ill have to upgrade and screw 32 im going 36.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
