corvette wheels?
Old Jul 19, 2006 | 11:06 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
corvette wheels?
on ebay they say they will work on 4th gen...and i heard you will need spacers for the 3rd gen...if so what spacers will i need?? thanks
Old Jul 19, 2006 | 11:09 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
you will need to get 2" spacers and they will work
Old Jul 19, 2006 | 11:13 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
just 2" spacers for the back correct?
Old Jul 19, 2006 | 11:19 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
depends on the backspacing of the wheel you may only need 1.5 or 1.75 spacer
Old Jul 20, 2006 | 10:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It depends on what wheels you get, and what stance you want. I am running 4 17" C5 wheels, I am using 2" spacers up front, and 2.25" spacers in the rear, with a C4 front brake setup.
Old Jul 21, 2006 | 08:41 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i am running 17" and 18" c5 using 2" spacers up front and using 4th gen rear which is 4" wider then 3rd gens
Old Jul 22, 2006 | 12:44 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
Just curious, is the car's steering affected by the spacers in the front at all?
Old Jul 22, 2006 | 04:00 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i can say i havent noticed, but i havent done any real hard driving or corning to notice, but the spacers shouldnt effect your steering
Old Jul 22, 2006 | 04:58 PM
All that the steering cares, is that the tire tread is in the right place. It can't look out and see, and wouldn't care even if it could, whether that metal in the middle there is part of the wheel, or the hub, or a spacer.
I have C5 wheels on my car too; 2" spacers all around. Everything fits great.
Drone358
Dec 10, 2015 08:16 PM
Lanz06
Sep 14, 2015 07:16 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
