Anyone running 18 rims?
Old Jul 28, 2006 | 02:19 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Just a quick question about guys running 18 inch wheels. What tires are you guys running and liking?
Ive got 275/35/18 Kuhmo 712's
Old Jul 28, 2006 | 09:22 PM
Radiorick's Avatar
Car: '89 t-bird SC/87 Z-28 vert
Transmission: auto
18" wheels
I'm ready to put on some 18" rims on my '87 camaro z28 convertible. How do yours fit? I'm not sure what size will fit. I was told 245 x 45, but i'm not sure. Any suggestions? Thanks Rick
Old Jul 28, 2006 | 11:39 PM
CrazyHawaiian's Avatar
Car: too many ...
The wheel width really matters, espeially when talking bigger diameter wheels that run smaller sidewall tires. So anyone looking for specs should include the width of the wheels they're using.
I'm running 275/35/18 on the rear with 18x9.5 wheels, here's a picture:
When determining tire fitment I usually use a tire calculator to determine the overall heights of the tires I'm considering using, then I find out which manufacturers make tires in that size, then I verify the wheel width I'm using is within the tire manufacturer recommended specs. This info can be found on the tire spec .pdf files on most tire manufacturer websites.
Old Jul 29, 2006 | 12:42 PM
Radiorick's Avatar
Transmission: auto
wheels
Thanks for the help. Rick
When determining tire fitment I usually use a tire calculator to determine the overall heights of the tires I'm considering using, then I find out which manufacturers make tires in that size, then I verify the wheel width I'm using is within the tire manufacturer recommended specs. This info can be found on the tire spec .pdf files on most tire manufacturer websites.[/quote]
Old Jul 29, 2006 | 04:05 PM
superNOScamaro's Avatar
Car: 91 CAMARO RS VERT
Transmission: t-5
Axle/Gears: 10 bolt/3.08
check out this link these are my wheels and my information on wheels and tires are in here
https://www.thirdgen.org/forums/auto...06-wheels.html
Old Mar 8, 2007 | 08:41 PM
91 VANE Z's Avatar
Car: 91 Z28 Convertible
Hi, did you have to lower your car when you put the 18's on?
Thank you
Old Mar 8, 2007 | 11:01 PM
Transmission: t-5
i lowered my car before i put my new wheels on. but you don't have to lower your car because you put bigger wheels. if you do lower it don't go to low because then you might run into rubbing problems.
Old Mar 10, 2007 | 01:11 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
im runnin 245/40-18's
there the exact same diameter as the stock 245/50-16's (i think thats what they were...)
im thinking about lowering it 1.5+ inches though.
Old Mar 10, 2007 | 11:13 PM
Transmission: t-5
if you are worried about rubbing i think you will be fine. the tire diameter is the same and there should be no problem with fitment.
Old Mar 11, 2007 | 01:29 AM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
i have 18" 275/35/18 on the rear and i lowered my 1.5" i would recommend it usless you dont mind the wheel gap.
Old Mar 11, 2007 | 01:38 AM
Randy92Z's Avatar
Engine: Miniram 383
I forgot about this post, LOL. I guess when I asked the question, I was more concerned with tire brand and ride quaility. What tire brands in the 18" size gives good traction and wear for the street, and what are some of you guys experiencing? Anyone like me running the car on the autoX course with there 18's? Thanks
Old Mar 11, 2007 | 04:31 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
oh i know they dont rub, but would they if i lowered it?
Old Mar 11, 2007 | 05:20 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Dub,
Nope, you will be fine.
Old Mar 11, 2007 | 07:52 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
Originally Posted by Billsblue89
Dub,
alright thanks
Old Mar 11, 2007 | 09:54 PM
Transmission: t-5
i have Kumho ECSTA MX tires and they grip really good for the street. i don't take my car on any autox or anything but coming around corners with some speed, they still stick to the road. i don't know about the wear for the track but for a performace tire i think they wear slower than expected.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
kyleb24
Aug 15, 2015 08:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
