SFC install Question
Old Aug 14, 2006 | 12:01 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
So i've had spohn's SFC's sitting in a box for months, and its time to get them installed. My query is.... if I just have them welded in, won't they "lock" the car in position with the middle sagging down?
I'm thinking I need to find a shop with a frame rail or something to compenstate for the sag in the middle before it's welded? What do you guys think?
Thanks,
Bill
Old Aug 14, 2006 | 12:06 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Sorry, but Im unable to help You. But I really wanna know the same thing ... So I will kinda just tap into this thread.
Old Aug 14, 2006 | 01:17 PM
Shagwell's Avatar
Car: projects.......
if you actually have "sag", then I would jack under the center of the car, slightly, thus pre-loading the sfc's - I did this with my vert, it helped some issues I had. I've yet to see a hard-top or t-top for that matter that was actually sagging, the doors, fenders, etc may be mis-aligned/sagging, but the body usually is not. The biggest issue is torsional stress(twist), which the sfc's can eliminate.
Old Aug 15, 2006 | 02:11 AM
wgripp's Avatar
Well, there's no visible sag. But, I know that there has to be some invisible sagging going on. I do have a hardtop, and there are small stress cracks (which I thought only t-tops and vers suffered from!)... and that's with only 50,000 miles. There are also scratches in the paint in the door wells.
Old Aug 15, 2006 | 02:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your scratches are more likely from worn door hinges. If you're worried about it, get your car checked at a frame shop before you install the SFCs. There's probably nothing wrong with it, though.
Old Aug 16, 2006 | 09:16 AM
wgripp's Avatar
What if i had the SFC's installed when the car was on a frame rail? Or is that not distributing the load properly or some cr*p?
Old Aug 21, 2006 | 12:51 PM
Shagwell's Avatar
most reccomend installing the sfc's while the car is sitting on the suspension(as in sitting on the tires). If you do it while suported from the frame you risk improper "loading" of the sfc's, and you could mis-align things(like the doors, the body). - As I said before, I doubt any of these cars are actually "sagging".
-wgripp - those stress cracks are from twist, yes hardtops get it too(verts don't, we don't have a roof to crack). - the doors are probably worn hinges, VERY comon with or 10,000lb doors. - CHP just did an article a couple months back about some new/improved greaseable(built in zerk fitting) door hinges for our cars, could be a big improvement.(I'm old-school, mine were long ago adjusted via the 2x4 in the door jam, pull and check until "re-aligned")
Old Aug 21, 2006 | 09:22 PM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
If your car sags, you have major issues and installing SFCs should be the least of your concerns right now.
In the position he is referring to in this quote, your car should not sag. A proficient F-body supported under the lower A frames and the rear end housing will not sag in the middle.
Old Aug 22, 2006 | 10:40 PM
wgripp's Avatar
Thanks for your help guys. I'm dropping my car off tomorrow to get worked on a J&S Performance in PA. Josh runs it, and is a member on here!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
