HAHA lots of questions, please help
Old Oct 18, 2006 | 10:29 AM
CAMOPARO's Avatar
1983 Camaro
I am putting a big block in this and was wondering what kind of heavy duty springs should i use in the front for drag racing?
Where can i get a good lowering kit for the car?
Where can i get the best frame connectors (weld in)?
Is it worth it to back half this thing?
I am wanting to go high 10's on motor
Old Oct 18, 2006 | 04:57 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
get a pair of IROC spring,
they're the stiffest spring that fits our car as far as i know.
subframe connectors and all that, theyre sold in lotta places
just click on couple banners in this website. good luck
Old Oct 18, 2006 | 05:28 PM
mmiller's Avatar
For drag racing you really shouldn't be looking for stiff front springs. You'd be looking for soft front springs and 90/10-style dampers (if struts for our cars are even made like that) that have little rebound damping and lots of compression damping. You'd probably want stiff rear springs, though. You should probably check out Jeg's for some drag-oriented suspension setups, because these are extremely different than setups designed to help you corner faster.
Old Oct 18, 2006 | 05:47 PM
CAMOPARO's Avatar
thanks for the help guys. yeah im really only concerned about going straight. is it even worth back halfing?
Old Oct 18, 2006 | 05:54 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
check out spohn's website. He has a dragracing coilover kit and sway bar setup and has very high quality parts from what ive heard.
Old Oct 18, 2006 | 07:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yea, lowering the car is for guys with neon lights underneath, you want to go fast straight line, don't bother.
moog 5664 is the stiffest parts store spring you can put in the front, a good choice for a big block, but more of a street application. Drag racing might like a different spring up there.
Old Oct 18, 2006 | 07:57 PM
mmiller's Avatar
Let me clarify something, too. I figure you asked for a stiffer front spring to keep the ride height the same after you add 200lbs of extra engine weight, right? And that would definitely be one way to achieve that. But you could keep the same spring and just use springs with a longer free length (or softer springs that are even longer). And if Spohn has a drag-race coilover setup, you can just raise the preload collars on those to get any ride height you want, regardless of spring rate. And those would also probably allow you more choices of rates and free lengths when you select the springs. I'd definitely check those out if you have money left over after the engine buildup.
Old Oct 18, 2006 | 10:20 PM
Camaroal's Avatar
Car: 98 Camaro
Engine: 441ci LS7
Transmission: th350
Axle/Gears: 4:10's
you can use moroso trick springs up front with a 90/10 strut
as for subframe connectors any weld in is god try competion enginering
if you want to drag race the car do not lower it it will not transfer the weight to get traction
as for back halfing the car you dont need to
the stock suspension works very well when it is set up right
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
Cleotiz
Aug 22, 2015 01:54 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
