wonder bar ?
Old Oct 21, 2006 | 08:38 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
wonder bar ?
k im just wondering how much a "wonder bar" is going to help out the handling/stiffness of my car. I found one on ebay for a reasonable price close enough to go and pick up. I am probably getting it. What will I need to do to make it work on my 89 rs convertible? any fabbing needed to make it work or just bolt it on? Where exactly does it bolt on to? TIA!!
Old Oct 21, 2006 | 09:12 PM
gray89vert's Avatar
Engine: 305 TBI LO3
bump i need to know soon to know if i should bid or not
Old Oct 21, 2006 | 09:48 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I think it is a must for all f-bodies
get it
Old Oct 21, 2006 | 09:54 PM
gray89vert's Avatar
Engine: 305 TBI LO3
k thanks. i bid on it. currently 1.75 lol. what exactly does it do? do i need to do anything to make it fit or will it just bolt in?
Old Oct 21, 2006 | 11:25 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
It acts as a brace for the forward half of the front subframe and also minimizes the chance of stress cracks around the steering box. Should bolt right in using the sway bar mounts. A very simple job.
Scott
Old Oct 21, 2006 | 11:30 PM
gray89vert's Avatar
Engine: 305 TBI LO3
thanks for the help! I plan on getting it painted or powdercoated red to match some of my other suspension parts. any suggestions on where to get this done? Can i take it to a body shop and have them spray it and put like 5 clear coats on it or something? thanks again
Old Oct 21, 2006 | 11:58 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Having it media blasted then powder coated will probably be your best bet for durability.Like Scottlb9 stated it mounts using the sway bar bolts.Just unbolt the 4 sway bar bushing bolts and leave it attached by the links,the "wonderbar" slips under the bushing clamps and reinstall the bolts.
It adds extra support across the front end,similar to installing a strut tower brace.It also takes stress off the steering box frame rail.F-bodys are know to develop stress cracks in that area.You will be happy with the addition IMHO.
Old Oct 22, 2006 | 06:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's the Global West version and its placement:
https://www.thirdgen.org/forums/atta...what-36mm2.jpg
By the way, the OEM Wonderbar went for something like $32 dollars new, so don't get carried away in the bidding. After market pieces aren't all that expensive either. IIRC, I payed $40 for my Global West piece (some time ago).
JamesC
Old Oct 22, 2006 | 06:49 AM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
They typically go for $50.00 shipped on E-bay. Anytime someone post a salveage car the first request is "Does it have a wonderbar, if so, how much?"
Old Oct 22, 2006 | 07:04 AM
JamesC's Avatar
Crazy. The OEM piece is simply stamped steel. The after market versions are far superior, especially for the money. Check out TDS, for example, before plunking down hard-earned cash on a 15- or 20-year-old piece. Lon's version is already powder-coated red.
Top-DownSolutions.com
JamesC
Old Oct 22, 2006 | 11:42 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Old Oct 22, 2006 | 03:00 PM
gray89vert's Avatar
Engine: 305 TBI LO3
i just looked and its up to 30 shipped now. so i will probably just order that one from Lon when I get the extra money. thanks again.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
