275/50/16's
Old Dec 21, 2006 | 04:53 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
275/50/16's
Will 275/50/16 tires fit on 8" wide iroc rims or would I be better off with the 255/50/16's. I'm getting some drag radials soon and can get the 275's a bit cheaper, not much of a deffernce though. Just wondering if I could use the extra width of the tire on the stock rim. Thanks
Old Dec 21, 2006 | 05:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
255/50s are the better choice
Old Dec 21, 2006 | 05:18 PM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
what company makes 275/50R16 DR's? i only know of 275/50R15 drag radials...
Old Dec 21, 2006 | 06:25 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
they dont make 275/50/16 i have looked all over! the widest for 16's are 255 and only a few companies make that size.
Old Dec 21, 2006 | 06:38 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
the closest i could find to a 275/50R16 Drag tire would be the Mickey Thompson ET Streets that are 26x11.50x16 but those arent a radial....
Old Dec 22, 2006 | 05:22 PM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
Yes, the mickey tompson are what I'm getting. I think they are 167 each from jegs for 255/50/16. A friend of mine said he can get 275's for 160 each, so figured I'd find out what size would be better. Thanks
Old Dec 22, 2006 | 05:28 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
are you talking about the ET street radials... because the only 16" size i know for them is the 255/50R16's.... there is no 275/50R16.... the only other size in the 16" for the ET street radials i can find is the new 295/50R16..but those arent even out yet...
are you sure your friend isnt mistaking the 275/50R15's as 275/50R16's?
Old Dec 22, 2006 | 10:34 PM
Dans87GTA's Avatar
this topic is brought up all the time they just dont get it. they dont make it! i work in a tire shop i see it all day long i think i would know! unless you go 26x11.50x16 but like said earlier its not a radial. the biggest they make is 255/50/16 do a search call whoever you want and they will tell you the same thing. the only reason why they make a 255/50/26 is for the C3 vette i think back in the day. they came 16x9.5 the turbine wheels. and that comes out to a 255. if im wrong someone show me proof. well atleast not yet. and thats what counts Later Daniel
Old Dec 23, 2006 | 11:59 AM
young82z28's Avatar
Car: Camaro
Engine: lt1
Transmission: 4l60e
I had never seen that size tire either, but he works at a dealership that does alot of performance work, so they carry alot of drag radials and slicks. Maybe he he made a mistake of the kind of mt. But I'm going with the 255. Thanks for the help.
FlippindaBird
21
Feb 18, 2013 07:45 PM
bradley23150
Wheels and Tires
Mar 29, 2010 01:28 PM
GNvsIROC-Z
Jan 24, 2005 02:06 AM
camaro430sut
Nov 28, 2004 04:47 PM
SMKNGTA
Mar 24, 2002 07:33 PM
