Where to find 10" tall springs for Ground Control Weight Jacks???
Old Dec 22, 2006 | 04:25 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
It seems like the 2 main companies are Eibach or SSS (Suspension Spring Specialists). So I went searching for 10" tall front springs at 650# and 11" rears at 125#. So I went and contacted a handful of Eibach and SSS dealers and haven't had any luck finding a 10" tall spring.
Any help would be much appreciated!!
Thanks,
- Joel
Old Dec 22, 2006 | 04:40 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
When in doubt. Check with Coleman racing!
11" Rear pigtail style.
http://www.colemanracing.com/catalog...?cPath=49_1154
Coleman doesn't list 10" front, but here is 9-1/2"
http://www.colemanracing.com/catalog...?cPath=49_1157
Other than that, Ground-Control should stock a TON of diffrent Eibach rates and lenghts, you might also try Strano Parts.
--John
Old Dec 31, 2006 | 04:40 PM
Engine: 6.3L - 383
Thanks for the link to Coleman John...I've forgotten about them.
That still is my problem though...Ideally a 10" front spring is what I want, but I can't find them anywhere.
I've spoken with a rep as SSS and I've also spoken with Sam Strano besides a handful of other spring dist. and have had no luck so far. 9.5" is the closest anyone has.
- Joel
Old Dec 31, 2006 | 06:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
650#? What are you trying to do, hold the front of the car up with one spring?
If you use a 12" spring you can use a spring from any rear coil over system. Competition Engineering has the 12" springs in 85, 100, 125, 150, 200 lbs/in
Old Jan 2, 2007 | 02:19 PM
Dewey316's Avatar
Car: 1990 Camaro RS
650 isn't very big at all, I am running quite a bit higher rate springs that that.
Are you worried about coil bind with a 9.5" spring? I guess I am not sure why you need a 10" up front, the weight jack should have enough adjustment in it, to get whatever stance you are looking for.
Old Jan 3, 2007 | 01:43 AM
CrazyHawaiian's Avatar
Car: too many ...
Hypercoils or Hyperco Coils, AFCO (rears), SCP Springs are a few. SSS springs are sometimes called "Blue Coil" since they are blue. You can order directly from any of these manufacturers (www.bluecoilspring.com for example).
Old Jan 3, 2007 | 10:31 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I bought 800# 9.5" fronts through Stranoparts.com last year for like 59.00 each. They are SSS. I had 8" springs in there and they were too short but the 9.5 is pretty good.
Old Jan 3, 2007 | 11:56 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
http://www.tcracecars.com/Merchant2/merchant.mvc
Website kind of sucks, but call the 800 number.
Old Jan 16, 2007 | 07:41 PM
Engine: 6.3L - 383
WOW...thanks for the help guys..I appreciate the feedback....I did not know there were so many spring manufacturers.
I'll keep you posted...I hope to have pics soon.
- Joel
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
