Standard Ride Height
Old Jan 1, 2007 | 08:56 PM
lthrneck's Avatar
Car: 89 Iroc
Axle/Gears: 3.70 9bolt
I have read about 100 post concerning spings for the 3rd GEN but I do not want to lower my car (not a fan of dragging speed bumps and driveways). Am I off my rocker here or can the camaro be lowered without it dragging the ground? Is there a standard ride height performance spring or will the all be 1"ish shorter? Thx for the help
Semper Fi
Lthrneck
Old Jan 3, 2007 | 07:57 PM
Pocket's Avatar
Car: 91 Trans Am
Since you read all those posts then you should know that the factory springs sag like crazy with age and milage
Lowering springs in many cases dont affect or lift the car compared to the old springs
Now that youve read that for the 101st time, gague your drop based on those youve already read compared to your already low riding mods. Most notably headers and aftermarket crossmembers
There is no magic number for you
Old Jan 4, 2007 | 05:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I suspect our car had issues with dragging straight from the showroom.
JamesC
Old Jan 4, 2007 | 04:36 PM
lthrneck's Avatar
Car: 89 Iroc
Yeh I think your right about the dragging from the factory. I compared mine to a bone stock 90% restored IROC today and its the same height...Guess it means need to slow the hell down going over stuff.
Old Jan 4, 2007 | 08:11 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Old Jan 6, 2007 | 05:29 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
At least with aftermarket springs the hieght is the height. With my stock set up I took the car out for the first time in over a year and tore up the front nose.......the car droppped without me knowing.
With aftermarket springs and the new ride height you get used to it and no guesswork.
Old Jan 6, 2007 | 08:29 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I believe Moog makes OEM style replacement springs. Check summitracing.com.
Old Jan 6, 2007 | 09:02 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I am currently installing these on my RS. I wanted stock ride height.
http://spohn.net/product.cfm?productid=1404
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Gunner242
Dec 25, 2015 04:49 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
skinny z
Oct 5, 2015 06:23 PM
Vincent135
Sep 28, 2015 10:50 PM
