autocross shocks/struts
Old Jan 10, 2007 | 12:18 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Just bought a poly bushing kit, and deciding on what shoocks and springs to go with.
I dont want to spend to much money so i figured this.
KYB AGX -$359 for the set
Tockico Illumina- $427 set
Everybody recommends the Konis for autocross, but the red's are over a 100 bucks more than any I have listed. Which do you guys think would be the best choice. Also anything else I should replace while im doing this swap??.
Oh and im guessing that the KYB AGX's are better than the GR-2's correct??.
Old Jan 10, 2007 | 12:30 PM
bluethunder28's Avatar
Koni or Bilstein if you want to be competitive. You should be able to get a used set for around $4-500 for Koni yellows.
Check on SCCAforums.com. Sometimes you can find them there.
Old Jan 10, 2007 | 12:39 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The AGX, toxicos, konis are adjustable which is what should be used for autox.
The GR2's are not. Thats what I have and did a bit of autox with. They are most likely the stiffest shock on the market for not being adjustable.
Old Jan 10, 2007 | 12:49 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Koni's hands down. It is the one off the self shock that people who are competative use. The other good options go up in price from the konis (re-valved bilsteins, etc).
Save the coin you are going to spend on springs, and get good shocks/struts. It will pay off.
Old Jan 10, 2007 | 04:20 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
I figured the konis too, but they are too expensive. Which is a better option the Illumina's or the Agx's??. What would be abetter choice for autocross??... Opinions seem split on this website.
Old Jan 10, 2007 | 04:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
You said you wanted to buy new springs too. From experiance, don't bother with springs, spend that money to get the koni's.
Of the two you listed, I would go with Tokico, but they are not even in the same ball-park as Koni.
Old Jan 10, 2007 | 06:48 PM
Dale's Avatar
Engine: 350 S-TPI
from my looking at pictures, and quick scans, toxico seems to be next favored below konis.
Only thing I dislike about the konis is I am told you have to dismount the bottom rears to adjust them. Where I dont belive you have to with toxicos and agx's.
Old Jan 10, 2007 | 07:44 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
I've run wik some used Bilstein (sports I believe) and used suspension techniques lowering springs. I was pleased. But, I just upgraded to koni's and 1000lb front springs. I'll let you know the difference after the end of the month.
I do agree w/ the 'save you coin'. It doesn't seem like you've been ax'ing for too long. Unless you're current shocks are leaking, I'ld just leave them in there and get more seat time, then buy koni's. Take that back. First thing I'ld buy (if you don't already) is another set of wheels and tires.
Old Jan 10, 2007 | 07:49 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
Go Koni and never look back. If you ever get competitive you will end up switching to these anyways. Look for used sets. They're on this board more often than you would think.
Old Jan 11, 2007 | 02:28 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I've run Konis for 6 years and love them.
I have never messed with adjusting the rears, just the fronts. And the top drivers that I have talked to on the subject leave the rears at full soft also. I'm not saying your doing anything wrong by adjusting them. For me it is just easier to play with the rear springs, bar and tire air pressure.
Old Jan 11, 2007 | 03:34 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
1000 for the fronts? wow. those are stiff.
Old Jan 11, 2007 | 03:39 PM
Dale's Avatar
Engine: 350 S-TPI
I dont have adjustables. I'm just going by what others have said.
Old Jan 12, 2007 | 02:43 AM
Not if you get T-bird rears or the 4th gen rears (yellows only). You can get the Koni yellows for the front and Koni reds for the rear since you want the rear soft.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
KeithO
Sep 25, 2001 06:28 AM
Cricket92RS
Dec 24, 2000 12:24 PM
