wheelies
Old Jan 28, 2007 | 06:20 PM
shaolink9's Avatar
Car: 1986 z28 <sold>
Engine: iron head 383
Transmission: th350
Axle/Gears: 4th gen 3.23 posi
wheelies
hey yall question i want to set up my street car so its more prone to wheelie. Not a big monster wheel stand but pick the wheels about a foot or so off the earth how would i go about setting up my suspension to help to so .....the motor is a 383 any help id really be thankful.
Old Jan 29, 2007 | 02:04 PM
Desert86Roc's Avatar
Do you run 10's in the quarter? Otherwise you dont make enough power to lift the front end of a 3600 lb car.
Old Jan 29, 2007 | 06:15 PM
shaolink9's Avatar
Transmission: th350
ok well in that case guess i dont have the power...thanks alot for ur help
Old Jan 29, 2007 | 09:00 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
take as much wieght as you can possibly think of off the front end...that always helps...less wieght up front less power needed to lift the front
Old Jan 29, 2007 | 09:08 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
TIRES.. if its not drag radials, slicks, or DOT slicks, you dont have a chance.. secondly, weight transfer.. soft springs, soft struts and shocks, LCA relocation brackets, LCA's, torque arm, panhard, and move weight from front to trunk(anything and everything)..
Old Jan 29, 2007 | 09:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Take a bunch of weight off the front end and put some 6.00 gears in the diff. That should produce enough torque to lift the front wheels.
Old Feb 4, 2007 | 02:58 PM
Kandied91z's Avatar
lol... thanks for making my day with this one!
Old Feb 4, 2007 | 09:35 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
Go to walmart and buy a small waterbed mattress put it in the back and put as much water in it as you can. This will help alot.
overdriv
Aug 20, 2015 03:52 PM
Iroc Adio
Oct 27, 2008 01:19 AM
AlkyIROC
Oct 16, 2005 11:01 PM
caribbean 85
Jul 9, 2005 07:36 PM
One Eyed Jack
Theoretical and Street Racing
33
Jul 8, 2001 11:01 PM
