36 MM hollow bar????????
Old Mar 7, 2007 | 10:35 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ok just bought a 36 mm hoollow bar, is it better or worse than a solid bar?????????? Or is that the way they came??? i paid 25 dollars...good deal or bad.....?????? please tell me about this bar, as I have never seen a hollow bar...My car had a 30 MM solid bar on it...Thanks guys............BTW I love my CAMARO.........The guy at the junk yard said it might be a aftermarket bar, but I dont know........BEER...............BEER............Front bar.....
Old Mar 7, 2007 | 11:34 PM
Guest
Guest
Posts: n/a
Any difference between the two performance wise would be minimal. The hollow bar is a lot lighter though, so thats a good thing.
Old Mar 8, 2007 | 12:42 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
The 36mm hollow is stiffer than your old 30mm. I think the 36mm hollow compares about the same as the 34mm solid.
Old Mar 8, 2007 | 05:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The hollow 36, solid 24 combo is fairly common.
JamesC
Old Mar 8, 2007 | 06:34 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks guys answered my question....
Old Mar 9, 2007 | 12:05 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I'm looking at buying one of these, but I can't find polyurethane bushings for it. I have the 30mm solid bar right now too so there won't be much of a performance gain just weight loss? How much difference is there in the weight?
Old Mar 9, 2007 | 12:16 PM
JamesC's Avatar
TDS, a board sponsor, sells them.
JamesC
Old Mar 9, 2007 | 05:48 PM
Guest
Guest
Posts: n/a
Maybe I should rephrase/clarify my post.
Between the 30mm solid and 36mm hollow, there will be a big difference. Between the 36mm solid and 36mm hollow, almost no difference.
Old Mar 9, 2007 | 08:16 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Well just got thru changing it, and the car feels "heavier" in the front now, guess it will take a while to get used to it..I now have 36 front 24 rear...Had a 30 up front.....
Old Mar 9, 2007 | 09:10 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I have the 36 up front and a 25 in the rear. I used to have 34/21 (F41 suspension).
The 36 in the front works perfect for me. The car really feels more planted in a turn and I have very little body roll. It is a better bar for me than the old 34 was.
The 25 is too much. Won't let the weight transfer to the outside of the car correctly, causing a loss in traction. I am going to a smaller bar in the rear. Possilbly a GM 21 solid or a StranoParts 22 hollow. (wish I hadn't been a moron and trashed the stocker...)
Spohn sells greasable bushings for the 36 fronts.
Old Mar 9, 2007 | 10:40 PM
Car: 2012 Corvette
Engine: LS3
Do y'all think the 36mm would be to much for my car since I only have a V6 and it doesn't weigh as much?
Old Mar 9, 2007 | 11:01 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Depends on your driving taste and what shocks/springs you have. Wouldn't hurt to try (other than wallet)
Old Mar 9, 2007 | 11:38 PM
Car: 2012 Corvette
Engine: LS3
I guess I'm an aggressive driver. I like to have fun when I drive and take turns as fast as possible. My V6 isn't that great in a straight line (although most of the time I have no problem passing people) so until I can get a new engine I want it to be great in the curves. I have 1" drop springs, KYB GR-2 struts and Gas-A-Just shocks, and 275 tires all around.
Old Mar 9, 2007 | 11:43 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Personally, I would invest more in the shocks/struts before I do anything else. You will see the most gains there. But, I would venture that the 36 mm would help you as well.
I'm agressive too. A LS1 SS and TA couldn't get away from me on a road they knew well. And my L03 is pretty much stock. Yeah, they weren't happy.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
