BF Goodrich 295/50-16
Car: '89 Iroc Camaro
Engine: 5.7 350 TPI
Transmission: 700R4 Automatic
I am considering putting these BFG 295/50-16's on my '89 Iroc on the stock 16x8 Iroc rims. I want to hear what people think of how these tires look, perform, and things like that. And please don't bash 'em if you haven't tried 'em, but all opinions are welcome. By the way, I have 245/50-16 Fuzion ZR's up front. Thanks.
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Re: BF Goodrich 295/50-16
that tire is way to big for what your doing and if you mean the radial t/a that one of the biggest pos tires bfg makes i know i sell tires for a living. i highly recommend not going that route. Later Daniel
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
i have to agree with Dans87GTA i had those on my 92 rs and they where by far the worst tires ive ever had, they wouldnt hook for anything.
Engine: 5.7 350 TPI
Well, from my experience, nothing but a drag radial or better will hook up on these third gens. I'm daily driving my Iroc to and from school and work, and am purely going for looks on this one. I don't push my car very hard in the turns, and being a daily driver launch/hooking up/traction is not a very big issue.
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
I would worry about 295's being too wide for those wheels. I would definitely go a bit smaller. I am running 245/50R16 BFGoodrich Comp T/A's on my stock wheels. Also, I am not a big fan of BFGoodrich either, but they do look good. In my experience they wear out extremely fast for the limited traction they provide. I like the Nitto 555's... They wear out fast too, but they are STICKY!!
Car: 1989 IROC-Z
Engine: 5.7
I just saw that you are from Topeka!! I used to live in Liberal and we went to Topeka alot for the Heartland Nationals! Very nice track.
Car: 82 Trans AM
Transmission: th350 turbo
in my sig below im running cooper cobras that are 265/50-r15's all the way around on 1969 corvette rally rims. fit fine and look nice. they hook nicely on dry pavement. just dont slam on the brakes in the rain if possible. thursday im getting my 295/50-r15's for the rear and keeping the 265's up front. i also got a different backspaced rims so i dont rub the inner rear fender wells.
Engine: 5.7 350 TPI
Just FYI everyone, the 295/50-16 BFG Radial T/A's are selling for 107 each on Ebay right now.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i was gonna get the gfg 295's, they were on cr4aigslist for $60 should have got em.
i meant bfg's
i meant bfg's
Last edited by 8T9 BANDIT; Apr 12, 2007 at 02:24 PM. Reason: Automerged Doublepost
As Dans87GTA stated, they suck! They won't hook or handle as well as a decent 255, and by putting them on too small of a rim(your 8 wide), they will wear even worse than normal.
Put properly sized tires on your car, thus not risking the rest of us on the road. If you want wide tires, get a wide enough wheel to support them.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
295's are too large for those 16" wheels. You won't like the handling and ride at all (if you've experinced a good performance tire before).
I wouldn't do it.
I've got a used pair of BFG Comp T/A 265/50r16's in very good condition for sale in the Toronto area.
Yes, that size is no longer available.
I wouldn't do it.
Last edited by freestylzz; Apr 14, 2007 at 02:14 PM. Reason: Automerged Doublepost
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
you need to go with a smaller tire. The 295's are just too big and won't handle well. Junior Member
Car: 82 Trans AM
that was one issue i believe i had with my previous wheel/tire combo. i had the 265's all the way around on 8 inch wide original 1969 vette rallies. now i have 10 inch wide rims and the 265's up front sit much better. now that i have 295's for the rear, ive noticed it takes a little more power to turn them over. i plan to get some other rims though to tuck them in further. these are the only rims i currently have because my dad wanted his rims back...
and to novamanx if your referring to me, im sorry, but i do not have the other two remaining 265's...i had to have something to burn up at Michigan's annual dream cruise!!
blackandblue02
Sep 10, 2015 08:19 PM
