bigger front sway bar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
I got a bigger front sway bar for my car. a guy gave it to me, but it seems to be alot bigger and rounder then my sway abr i have now. its out of a 91 formula. what would i benifit from putting this bigger sway bar in my car? i already got a bigger rear sway bar. thanks
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: bigger front sway bar
What sizes are the bars (front and rear)? Do you have other modifications?
Car: trans am ws6
im not sure, on my car currently it was all stock, just a 91 firebird 305. but now i put a formula 373 rear end in it with that sway bar and a front sway bar.
Car: 1991 RS Camaro
Well, it would be a better match for the rear bar. I think it would be a good idea. I am running a WS6 sway bar from a 91 Formula on my car now.
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Well I put 36/24 on my car, and I've notices a difference. Can take corners at sweet speeds and stay level.
Car: 1991 RS Camaro
I have 36/25.4 and mine is super level...just a little too much rear bar, though. Doesn't like much throttle when exiting a turn. Causes over-steer.
Car: trans am ws6
thanks guys, think ill put it on since im doing everything else to it. thanks
Car: 1991 RS Camaro
If I can make a reccomendation... try to get some polygraphite bushings. The stiffness and durability of polyurathane without the squakiness. I want to replace the poly on my car with polygraphit this summer.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
