Prolines Vs SportLines...Which one to get?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
1988 WS6 Firebird Formula 350. Sub-frame connectors, STB, Wonderbar, Polyurethane Bushing, Stocks Wheels. Picture in Sig. What should I get Proline or Sportlines?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Prolines Vs SportLines...Which one to get?
Which do you guy think would look better with my stock formula rims? Does the Pro kit really only drop it an inch, or does it settle and get a little lower?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Yes, Pro Kit, My bad, That is what you get when you add Prokit to sportline...You get Proline. Haha, Sorry.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am thinking the pro kit will look best with the stock wheels because it isn't too low. But will it settle to lower it more than an inch?
Car: Pair of 92 Z28s
No, and you may not actually see a 1" drop if you are still running the factory springs on your car now. Factory springs sag and often times ive heard of people adding pro-kit and keeping the same ride height.
I have pro-kit on my car, satisfied with the front but my rear didnt lower enough.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have the WS6 suspension and it is very firm, I dont think it is sagging at all.
here is how my car looked with the Sportlines and stock wheels,
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How did you like it slammed with the stock wheels. Which kit would you get will the stock wheels since you already had one kit. So would you stick with the sport lines with stock wheels or get the pro kit?
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
get the prokit , sportlines ride tough with my 18s and upgraded suspension , but your on stock wheels and have a lot of sidewall compared to me , so . but i think the prokit.
TTA850
Feb 24, 2013 08:35 AM
