rear sway bar? ditch it?
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
when i put my 12 bolt in i drove without the rear sway bar for a week or so and the car tried to hook hard on my street tires. never put my slicks on. is it better to run with or without it at the track?
Re: rear sway bar? ditch it?
You should run with the rear sway bar. The car can get lots of body roll without a rear sway bar. This will cause the car to pull and to unload one tire a little. Race-only cars will typically have a very heavy rear sway bar.
Some people like to ditch the front sway bar to help prevent any resistance to the front end rising. This helps the car react more consistently and to smoothly unload the front suspension as weight transfers to the rear suspension. Personally, I would keep both for any street driven car and work on keeping the suspension as bind-free as possible.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I ran for years without a rear sway bar when I was using ladder bars.
Last winter when I switched to a 4-link, I noticed a big change in the way the car was launching. No matter how much preload I was putting on the RH upper bar, the car would not launch straight. Every time I launched, the car would pull and roll to the right and I would fight to get it straight again.
I invested in a rear anti-roll bar and now I wonder how I managed without it. The car now launches dead straight with no body roll or pulling to either side.
The factory rear sway bar isn't the best thing to use but it's better than not using one at all.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
If you are running stock-style suspension, I say keep it and get a big one. What I've seen about everywhere.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i run the stock sway bar in the back with 2 different length endlinks and i'm happy with it
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
preload on the passenger tire.. when you launch(looking at the car from the back) the axle will rotate counter clockwise, forcing the drivers tire into the ground and lifting the passenger tire.. by preloading the passenger tire with more initial weight, the rotation from launch wont throw off the weight distribution between the tires and give better more even traction
EDIT: keep the sway bar.. throw on some poly bushings too.. i use coil spring spacers as my preload device.. you may hear of airbags too..
Car: 1972 SS Nova, 1991 Camaro drag only
Engine: Stock 350, 355 w/12.5's
Transmission: 350 auto's
Axle/Gears: 3.55, 3.73
So on a factory stock chassis you may need to lengthen the drivers side endlink to make the car go straight?
Car: 1984 Trans Am
not necessarily.. some cars go as straight as an arrow from the factory.. some dont..
you will want the longer link on the passenger's side. You want to increase the load/resistance on the passenger's side.
The WS6 rear bar is the toughest factory bar, there are a few aftermarket bolt-in drag only bars that are even heavier. - If you have any fab skills or a decent shop close by an anti-roll is a nice way to go, and tune-able.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
you want a sway bar.
check out the white car.
its in need of a anti roll bar. its hell on the track.
http://media.putfile.com/EC-1-27-08
So that white does not have one at all? If that is what is going to happen I will leave mine alone.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
nothing at the moment. he put the 9" in and it drove fine so he didnt want to waste the money on the relocation brackets for the car.
mine never got ugly like that without a bar, but it does 60ft better with one.
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
